I am trying to find a male component that will fit the female component described and pictured below. Unfortunately I do not have the male end to provide pictures of. Any help identifying this connector or any tips for identifying connectors are much appreciated.
40-pin
20.3mm long
3.2mm wide
unknown pcb conector
As @EugeneSh. said, it is most likely a standard 20x2 rectangular 1mm pitch connector.
The female part could be compatible with these:
SAM9228-ND
And the male part could be compatible with these:
455-1868-1-ND
Although it's difficult to tell from your picture whether that's raised enough to accept the shroud on the linked part.
