9
I'm integrating an nRF24L01+ chip into a PCB I'm designing, but I'm a little confused about the best PCB antenna design. In the datasheet for the chip, they specify an antenna like this:
nRF24L01 recommended antenna
However, all of the boards you can buy with this chip use a different design:
nRF2401 board
The design is quite different. Not only is it a different shape, it also has that extra stub track with a via.
What is the reason they do this? Is it a more effective antenna, or does it just take up less PCB space?
If it is a superior design, how can I create my own? Do I just draw a wiggly line that looks roughly similar, or do I have to get the dimensions precise for it to work properly?
    \$\begingroup\$ I did some testing with nRF's lately (the one below, with small PCB antenna), and the orientation and vicinity of other metalic elements is quite important. \$\endgroup\$ Aug 8, 2017 at 22:07
Both?
The meandered part is probably an inductive element, increasing the electrical length, and the stub might match the impedance. Looks a bit like an inverted-F antenna.
In fact, it's a meandered inverted F in PCB shape. Probably, you'd call it a MIFA
"If it is a superior design, how can I create my own? Do I just draw a wiggly line that looks roughly similar, or do I have to get the dimensions precise for it to work properly?"
Antenna design is not going be easy. Here is a link on how I would design an antenna.
http://colinkarpfinger.com/blog/2010/the-dropouts-guide-to-antenna-design/
You neeed to remember this, tune the antenna inside a case as a finish good with a complete assembly. Tuning it bare PCBA won't be accurate, once the antenna is in close proximity with other stuff surrounding it; the frequency will shift away slightly.
