What will happen to the current if a diode is placed the wrong way round?
Should the current be 0?
I need to measure the current when the diode is the wrong way round.
Thanks
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhat will happen to the current if a diode is placed the wrong way round?
Thanks
Diodes have a small leakage current when reverse biased and that is the current you will measure - leakage current: -
Normally there will be reverse leakage when a diode is reverse biased. Due to the increased potential, holes on the n side of semiconductor are dragged to negative terminal of the battery and electrons on the p side is dragged to the positive terminal of the battery. This constitute a reverse a current which is a also called as reverse saturation current. This is because even though increase in reverse potential, current will not be increased that much for a certain limit. This leakage current varies with diodes according to the spec sheet.
