-4
I want to make a led glue stick lamp but i want it to power from 220-240v ac. See link https://www.youtube.com/watch?v=faNXVuPnZIE As all time 9v battery will be costly for me so i want to do this.
  • \$\begingroup\$ What are you asking? \$\endgroup\$ – Colin Aug 9 '17 at 11:56
  • 4
    \$\begingroup\$ I'm voting to close this question as off-topic because it isn't a design, nor even electronic question. Actually, it isn't even a question. \$\endgroup\$ – R Drast Aug 9 '17 at 12:20
  • \$\begingroup\$ if you don't care about flicker, you can just use a series resistor. a capacitive dropper would provide smoother output. \$\endgroup\$ – dandavis Aug 9 '17 at 17:44
  • \$\begingroup\$ Bro i don,t know about the flicker, series resistor or capacitive dropper can you please explain me. \$\endgroup\$ – Rishabh Patel Aug 10 '17 at 15:13
I would assume that from the lack of information in your question, your electronics knowledge and experience is currently limited?
If this is the case please dont 'play' with 220VAC
I would suggest finding a suitable mains-powered 'wall wart' power supply. You should be able to use any one which gives sufficient current and voltage for your LED setup - and where you dont have 9V from the adapter you can change the resistor values to suit - many many free calculators for LED / Resistor online :)
