I apologize in advance for posting a homework problem. I am given this simple BJT circuit as shown below. I have to find the base-emitter voltage with reverse beta equal to 0.5 and forward beta 50. Also a saturation current of 10^-16 A is given, which doesn't sound right to me, but is written anyway in the problem.
I haven't encountered this biasing configuration before and so I have no idea how to proceed except that the collector current can be found to be 12.5 mA using the provided current gain. Aside from that I don't see any reason why the base-emitter voltage would not be 0.7 volts as usual, but the problem states that the correct value is 0.84 volts. I also want to know what this kind of bias setup is called.
The clue is in the reverse saturation current of 0.1 fempto amps. It is (I suspect) leading you to use the ebers-moll model of a BJT: -
I'm not going to reverse engineer this equation to solve for Vbe (given a collector current of 12.5 mA) but if I plug in the answer of 0.84 volts, I get a collector current of 26.23 mA.
If I plugged in 0.83 volts I get 17.7 mA so maybe the author of the question has either done an over-simplification or you haven't provided some information that is vital like ambient temperature.
So, if Ic = 0.0125 amps I get Vbe to be 0.82 volts.
Maybe (?) also the internal emitter degeneration resistor (\$r_e\$) has been factored into the answer: -
With a collector current of 0.0125 amps \$r_e\$ is about 2 ohms and assuming emitter current = collector current, the base will need to be 25 mV higher bringing Vbe up to 0.845 volts.
It isn't a real bias setup used in practice - the current injected into the base (as shown) could come from a voltage supply in series with a resistor but this would create an inaccuracy in how you treat the problem.
  • \$\begingroup\$ This is very handy. I did not know this. Btw room temp de facto around here is 300 K. Thanks Andy. \$\endgroup\$ – DorkOrc Aug 10 '17 at 3:04
Assume the transistor behaves as a diode
Ie Vbe 1nA 0.7 - 6 * 0.06 = 0.7 - 0.36 = 0.34 volts
1uA 0.7 - 3 * 0.06 = 0.7 - 0.18 = 0.52 volts
1mA 0.7volts (assumed)
10mA 0.7 + 0.06 = 0.76 volts
Get the collector current from Beta is 12.5mA. Ignore the base current or not. This equation solution is (ln(0.0125A/1e-16A))*0.026V = 0.84V You can ignore subtracting the one when you solve the diode equation. I'm assuming Vt is 0.026V.
