Some one knows what kind of sensor is this and how it works? Is from a vacuum robot. I guess to check something on floor. I would like to connect it to Arduino.
    \$\begingroup\$ If you don't know what it is, what is the motivation for connecting it anywhere? \$\endgroup\$
    Aug 10, 2017 at 11:13
  • \$\begingroup\$ Hi @Andyaka. Just to learn. I'm not a electronics/HW man :( \$\endgroup\$
    – danihp
    Aug 10, 2017 at 11:26
That appears to be some sort of fluorescent lamp. Note that the wires to the connector are labeled IN+ and IN-, and the wires to the lamp OUT+ and OUT-. That doesn't make sense for a sensor. The transformer also hints at high voltage being made, as would be required for such a lamp.
It might be a germicidal UV lamp. Those are a form of fluorescent lamp, but their function isn't available from LEDs. That would also explain the apparent lack of phosphor coating the inside of the bulb.
  • \$\begingroup\$ oh! Thanks. At this time I'm not able to figure out any project with a germicidal UV lamp on Arduino. Nice to meed you Olin. \$\endgroup\$
    – danihp
    Aug 10, 2017 at 11:29
  • \$\begingroup\$ Olin, you are right!! Here it is: rexim.com/pages/ccfl/mccuv.html \$\endgroup\$
    – danihp
    Aug 10, 2017 at 11:47
