I have reset synchronizer in my top block (attached file). In my project I have blocks which get 125_clk, and others 250_clk. In addition I have srstn_sm block which its output is input for srstn input of many blocks (attached file).
The code for the srstn_sm block:
entity srstn_sm is
  generic(
    reset_duration_cc_g : positive := 10
  port(
    clk         : in  std_logic;
    sft_srst_in : in  std_logic;
    srstn       : in  std_logic;
    srstn_out   : out std_logic
-- Declarations
end srstn_sm;
architecture behave of srstn_sm is
  type   sm_states is (IDLE, RST);
  signal sm_state  : sm_states;
  signal srstn_cnt : natural range 0 to reset_duration_cc_g;
begin
  srstn_sm_proc : process(clk)
  begin
    if (rising_edge(clk)) then
      if (srstn = '0') then
        srstn_out <= '0';
        srstn_cnt <= 0;
        sm_state  <= IDLE;
      else
        case sm_state is
          when IDLE =>
            srstn_out <= '1';
            if (sft_srst_in = '1') then
              srstn_out <= '0';
              srstn_cnt <= srstn_cnt + 1;
              sm_state  <= RST;
            end if;
          when RST =>
            if (srstn_cnt = reset_duration_cc_g-1) then
              srstn_out <= '1';
              srstn_cnt <= 0;
              sm_state  <= IDLE;
            else
            end if;
        end case;
      end if;
    end if;
  end process srstn_sm_proc;
end architecture behave;
As both clocks are in phase and one clock is an integer division of the other, I want to synchronize the reset to the slower clock, because every rising edge on the slow clock will also be a rising edge on the fast one. Should I inesrt 125_clk/250_clk to the srstn_sm block?
How the requirement time is calculated in each case?
What if this reset (which is syncronized by 125_clk) is an input for block which gets 250_clk. It the requirement time will be 4ns or 8ns? Should I handle this in a special way (multicycle_path or something else...)?
clk and reset waves
sm_srstn
  • \$\begingroup\$ The task of a reset synchronizer is to synchronize a reset signal from one clock domain to the other and implement some specialties for resets. So at first, if both clocks are related to reach other, you don't need such a circuit. At second if the are unrelated, then your circuit doesn't handle the metastability problem, which is the main reason why you need a synchronizer. A synchronizer will always need the output clock, and some may also need the input clock to capture the data before synchronizing. \$\endgroup\$ – Paebbels Aug 12 '17 at 5:49
  • \$\begingroup\$ You can find a set of synchronizers here: poc-library.readthedocs.io/en/latest/IPCores/misc/sync/… \$\endgroup\$ – Paebbels Aug 12 '17 at 5:49
  • \$\begingroup\$ @Paebbels - the sm clk works with 125_clk, where the second block which gets the srstn_out as input works with 250_clk. \$\endgroup\$ – sara r Aug 13 '17 at 7:54
  • \$\begingroup\$ @Paebbels - the syncronized reset is on top level. The srstn_sm block works with 125_clk. Its output (srstn_out) insert to various blocks. and some of them work with 250_clk. So the question is - Is the requirement time will be 4ns or 8ns? Should I handle this in a special way (multicycle_path or something else...)? \$\endgroup\$ – sara r Aug 13 '17 at 8:26
