I am looking for an op amp to use as a unity gain buffer with a disable feature. The OPAx890 looks like a good candidate because it is unity gain stable.
I have noticed that some op amps labeled as unity gain stable have worse stability than others (e.g. OPA690 claims unity gain stability, but its stability is poor. The G=+1 small-signal frequency response shows >3dB of peaking in the datasheet).
The OPA2890 has a very nice looking small-signal frequency response in a unity gain configuration: enter image description here
I do not need a dual op amp. I was glad to find that there is also the OPA890 which looks like a single version of the OPA2890. It looks like the OPA890 has worse stability with some peaking at G=+1:
Does this make any sense? I would think the same op amp would have the same frequency response, or for the single to have better properties than the dual. Of course I can just get the dual and use 1, but is this an actual difference between op amps or just an error in the datasheet?
    \$\begingroup\$ How can there be stability issues when you use it as a follower? What does the word stability mean to you? Under which frequencies? \$\endgroup\$ Aug 10, 2017 at 17:29
  • \$\begingroup\$ Both are unity gain stable but one has a phase margin smaller than the other. \$\endgroup\$
    Aug 10, 2017 at 17:35
  • \$\begingroup\$ @HarrySvensson by stability issues I mean that when you hit the follower with a step response it will overshoot and ring. By stability I mean phase margin and the more the better. \$\endgroup\$
    – DavidG25
    Aug 10, 2017 at 17:36
  • \$\begingroup\$ Woaw, that's a new definition of stability. I don't like that. Over to your problem at hand, isn't that something that can be solved with a small capacitor to alter the phase margin? \$\endgroup\$ Aug 10, 2017 at 17:38
    \$\begingroup\$ Frequency response setup differs for these two graphs: one was done with 0.1V input, the other with 0.5V input. Could slew rate be involved with these different results? \$\endgroup\$
    – glen_geek
    Aug 10, 2017 at 17:45
It looks like there is an actual difference between the OPA890 and the OPA2890. For example, the parametric table on the OPA890's description page shows that the OPA890 has a slightly higher GBW (260 MHz vs. 250 MHz), higher slew rate (500 V/µs vs. 400 V/µs), lower offset drift over temperature (15 µV/C vs. 35 µV/C), etc. The electrical tables in the two datasheets show more specific differences as well. The OPA890 is a bit faster than the OPA2890 so it looks like the two figures in the datasheets are correct.
  • \$\begingroup\$ Okay so they're just different amplifiers and I was thrown off by the part number and the little table at the top that shows "related op amp products". \$\endgroup\$
    – DavidG25
  • \$\begingroup\$ @DavidG25 Well, they are related and probably share mostly the same design. But it looks like for some reason they are specified slightly differently. \$\endgroup\$
    – Null
    Aug 10, 2017 at 17:40
6
Yes it does, from what I've seen they manufactures can use different silicon sometimes for a dual vs a single or quad part. But without actually seeing the die layout there is no way to really know (you could get some nitric acid and microscope -- be careful-- and find out for sure).
The manufactures datasheets should reflect actual testing of the parts, and purchased parts should reflect the test data seen in the datasheets.
The difference probably a result parasitics, maybe the die wires are shorter in the OPA2890 since they might have put two separate dies in the same package. Or it could be due to more capacitance in the OPA890. Its all in the parasitics of the package or testing, or both. I'd trust the datasheets unless you want to get a part and do the testing on your own, the datasheets should reflect actual testing done by the manufacturers engineers.
  • \$\begingroup\$ This makes a lot of sense. Same design but with different parasitics would give different results. I wish I could choose both your and Null's answer, but I'll just give you +1 for the good info. \$\endgroup\$
    – DavidG25
    Aug 10, 2017 at 17:44
