I have an ATX power supply with a +12V 8A line and a -12V 0.8A line. I assume if I used the -12V as ground to provide 24V, then the maximum current provided by the 24V line would be 0.8A?
    \$\begingroup\$ Correct. ______ \$\endgroup\$ – Tom Carpenter Aug 10 '17 at 20:57
    \$\begingroup\$ @TomCarpenter 6 underscores.... is the blank "Friend"? \$\endgroup\$ – Asmyldof Aug 10 '17 at 21:26
Your assumption is correct. \$\$
