Unknown SMD resistors
What are the blue components seemingly labeled "69:1" in the attached image? There is reason to believe that they are resistors, but of what value?
I thought perhaps the ":" is a "00" written on top of each other - but I couldn't find a 5 digit SMD resistor coding convention.
    \$\begingroup\$ The AD829 is a 100+ MHz video amplifier. The components are likely some inductors, or specialized band-pass ceramic filters. Some reverse engineering of schematics would help here. \$\endgroup\$ – Ale..chenski Aug 10 '17 at 21:28
    \$\begingroup\$ What reason do you have to believe they are resistors? The package? \$\endgroup\$ – Passerby Aug 10 '17 at 22:22
    \$\begingroup\$ Slap an ohm meter on them and report your findings \$\endgroup\$ – Voltage Spike Aug 11 '17 at 0:07
  • \$\begingroup\$ Try 6980 ohm, 1% tolerance. \$\endgroup\$ – glen_geek Aug 11 '17 at 1:59
  • \$\begingroup\$ @glen_geek Unsoldered them and measured - 6960 Ohm and 6970 Ohm. Now the question just seems silly. How do we mark this as resolved? \$\endgroup\$ – Berry Pi Aug 11 '17 at 17:32
Per the comments, the assumed colon was actually an 8.
SMD component was a resistor with value code 6981 (6980 ohm).
| improve this answer | |
