I'm working on a couple of solar panel projects here is the list of question I have.
1) I"m looking for a wire chart that shows how far you can run a specific gauge wire at 12vdc before there is significant voltage loss.
2) I have 18/4 cable, what gauge is the wire if i twist two of the conductors together?
3) I have a 35w solar panel how long does it take to generate one amp hour of power?
4) Lets say i have a 1 amp draw on a 65ah deep cycle battery and the draw is continuous for 10 hours (dusk till dawn) how may amps have i used?
5) Most boats have 2 battery banks. One house battery (for electric appliances) and one reserved battery to start the boat motor. I want to solar charge both batteries then disconnect the reserve battery so there is no load on it while i use the house battery. The solar charge monitor i have only has one battery terminal. I tried to wire the coil of a relay across the solar input terminal so that when there was sunlight the relay would close the circuit on the reserve battery so it could be charged but the coil took to much power there was not charge output the solar panel is only 10w. Where can i find a low current relay or what is a better method?
6) I'm setting up solar powered motion detector led lights but i can't put them in the sunlight and have them where that need to be....I want to set up a remote solar powered battery charging station then run wire to the motion detector led lights. another problem is that they are lower than 12vdc. Its simple enough to by pass the solar panel input then connect my own power supply. What is the most efficient way to drop the voltage to 6vdc step down transformer or resistor? is there an adjustable step down transformer?
7) I bought automotive 12vdc led lights they work great i could also set them up as motion detector led lights where can i get a 12vdc outdoor motion detector and a day/night photo electric switch?
8) last problem the solar panel i bought didn't come with mouthing brackets. I want to mount it on 2x4 then sit it on the ground but i need to adjust it to the correct angle toward the sun. Where can i get or make an adjustable bracket?
