ı want to buy a nxp LPC43S50FET256 processor and ı made some research but I dont know whether lpc43s50 has already got bridge connections, ı also dont know for example whether ethernet is already connected or not I couldnt understand from the datasheet and there is not enough information about this processor so ı couldnt understand whether this is an only processor or are there some other part which has already connected to processor for example ethernet and some other ports. Exactly what ı mean is whether this is a processor or microprocessor board
\$\begingroup\$ Welcome to EE.SE. Please run your question though a word processor. Hundreds of words but only one period and no question mark. \$\endgroup\$ – winny Aug 14 '17 at 11:59
\$\begingroup\$ thanks but ı will do this other time .I have already got my answer .Thanks for your suggestion. \$\endgroup\$ – user158660 Aug 14 '17 at 12:09
This device actually has two processor cores and includes many peripherals including an Ethernet MAC. It is not a development board it's an IC. By the way, it has no on-chip flash.
Not wanting to be rude, but if you can't glean this from that datasheet, it sounds like a heck of an undertaking for you.
Why do you want to use this chip specifically?
\$\begingroup\$ ı will use this chip to control an interface with I/O control by connecting an SSR , and other applications but by looking this datasheet ı couln't understand for example whether ethernet port has already connected or not as well as lcd \$\endgroup\$ – user158660 Aug 14 '17 at 8:56
\$\begingroup\$ Otherwise ı will have to add this ports externally \$\endgroup\$ – user158660 Aug 14 '17 at 8:57
\$\begingroup\$ what ı want to know is what this package consists of \$\endgroup\$ – user158660 Aug 14 '17 at 8:58
\$\begingroup\$ ı am an intern at company and ı have responsibiliy about how to connect and use ethernet port to Lpc43s50fet256 processor \$\endgroup\$ – user158660 Aug 14 '17 at 9:00
1\$\begingroup\$ ı really appreciate your efforts \$\endgroup\$ – user158660 Aug 14 '17 at 9:51
