I have an relay that's rated for a 250VAC, 16A load. Would it be possible to also use the same relay for say a 25VDC, and less than 1A load?
From here, relay power ratings - AC vs DC , it seems to imply that that due to arcing, an AC relay would be able to support switching DC as long as the DC voltage is about 1/10 of the AC rating.
Would this apply as a general rule even if DC values are not explicitly stated on the relay's spec sheet, as in, there won't be long-term damage from implementing relays in this manner? The particular relay I'm using is "G5LE-1A-E" with a rated load of 250VAC @ 16A, from here: https://www.digikey.com/products/en?keywords=%09Z2619-ND
  • \$\begingroup\$ Just as a general point, sometimes datasheet design isn't enough, and you have to become an experimenter and test the components to see if they are suitable for an application. This is probably that kind of case. \$\endgroup\$
    – Ian Bland
    Aug 14, 2017 at 23:06
No, this is not a general rule. The AC rating and the DC rating rely on different relay qualities.
The AC rating allows for the arc that forms during relay opening to be extinguished by the voltage zero crossing, rather than the opening of the contacts. So the AC rating often says more about how long it can withstand an arc of a certain power level for, rather than how effective it is at interrupting the current.
The DC rating must allow for interruption of the full current at the full voltage rating. So to meet the DC rating, the relay must not only withstand the arc that forms as the contacts are opening, but also open far enough to extinguish that arc.
This is why you see with some relays, and indeed with the relay you specify, that one model is AC rated and another is DC rated - in your case, G5LE-E and G5LE-G respectively. The -G variety actually specifics the contact gap width, because that's important if it's the relay's job to extinguish the arc.
Of course, all relays form some sort of gap, so even an AC rated relay will work with relatively low DC. But how low? It depends. Be especially careful if you have any inductance at all in your load circuit. Interrupting a DC circuit with inductance in it is challenging, and pernicious, because the damage it causes may not be obvious at first.
  • \$\begingroup\$ What would be a solution to counteract any possible large inductance? By a large inductance affecting a DC circuit, I assume you mean that when the DC circuit is suddenly cut, a magnetic field collapses and causes the current to rush to the opposite direction. Would having a reverse diode on the contacts (EDIT: from the load connection to ground) help in this case? My application does not involve any rapid switching (maybe once every few mins. or so), if that helps. \$\endgroup\$
    – plu
    Aug 15, 2017 at 1:58
  • \$\begingroup\$ The inductance actually works to maintain the current flow. It's the voltage across the inductor that can dramatically invert, as it flips from being a load to a source. Unfortunately a diode across the relay doesn't work, because then the relay can't turn anything off (unless it's a high valued Zener, but then it has limited utility). The diode has to go across the inductive load, which can be tricky if the inductance is difficult to identify! \$\endgroup\$ Aug 15, 2017 at 2:18
  • \$\begingroup\$ Okay, that's good to keep in mind in case things don't work, thanks for your suggestions. \$\endgroup\$
    – plu
    Aug 15, 2017 at 3:13
From a safety perspective, its unclear. As you alluded to, the DC ratings are often much lower than the respective AC ratings. You're probably fine at less than 1 A for a one-off project.
If the project will require any type of safety certification (i.e. UL), you are better off getting a relay with the correct rating. Using an AC relay for a DC load will severely complicate the evaluation and will require you to take some additional responsibility.
