8
In super small low power devices, where space is a big premium, complicated passive networks can take up a lot of space. Is it possible to get a passive or mostly passive ASIC fabricated? If it is possible, how much would it cost? Obviously it would never approach the tiny cost of discrete passives, but when you really need that space it might be worth it.
In terms of costing for ASIC manufacture, this question was really helpful, but it's talking about more traditional ASIC's where the main thing is the active components.
I'm also wondering, maybe ASIC is the wrong word? Is there another word for this kind of thing?
  • \$\begingroup\$ What do you mean by "passive"? Like a bunch of tiny resistors and capacitors? \$\endgroup\$
    – Eugene Sh.
    Commented Aug 16, 2017 at 18:45
    \$\begingroup\$ Yeah pretty much. I guess you would just use FETs for resistors. Silicon capacitors are pretty inefficient spacewise, so it's not the best idea. \$\endgroup\$
    – BeB00
    Commented Aug 16, 2017 at 18:46
    \$\begingroup\$ So maybe you are talking about "analog" rather than "passive"? \$\endgroup\$
    – Eugene Sh.
    Commented Aug 16, 2017 at 18:49
    \$\begingroup\$ You go to great lengths to avoid resistors, capacitors and especially inductors in ASICs so you are in a bad spot to start with. What you do is create very weak current sources and minute small capacitors, opamp style intregrators and so on to fake the passive value you need. \$\endgroup\$
    – winny
    Commented Aug 16, 2017 at 18:57
    \$\begingroup\$ If you stated what application this was, it's possible we could suggest how that application could be converted from a passive circuit into an active circuit which could then be more easily placed within an ASIC. \$\endgroup\$
    – horta
    Commented Aug 16, 2017 at 20:01
4 Answers 4
20
Not an expert answer, but some disconnected relevant facts:
One of the reasons that ICs often require external passives is that standard silicon ICs are not a good substrate for making capacitors and inductors of significant value on-chip. Thus, a conventional IC, "AS" or not, is not a space-efficient way to put large passives on a board (other than high-value resistors). It might still work out to be an improvement if it's not the value but the number of parts that is a problem (i.e. packages and interconnects account for most of the area), but this is why, for example, your microcontroller always has external decoupling capacitors.
Resistor networks and capacitor networks are an existing common form of passives-in-a-single-package. I haven't heard of any mixed passive types in a single package, though — I expect it would be difficult in the same way as putting passives in a normal silicon IC because they have very different materials and manufacturing techniques.
Resistor networks can be used:
  • To save space on the board; they were much more common and relevant in the through-hole days, I believe, where even if you placed the resistors vertically you would need an entire hole for the other pin, and a network would let you have \$N\$ resistors with only \$N+1\$ pins).
  • As a high-precision voltage divider or other configuration of matched resistors (this is often seen in high-end measuring instruments). Multiple resistors made using the same process and on the same substrate can have tighter tolerance, more temperature-stable ratios of resistances than independently manufactured resistors.
Hybrid integrated circuits, or hybrid modules, are sort of an intermediate technology between PCBs and single-semiconductor-die ICs, which can include passives either formed on the board itself or soldered on — but they are not noteworthily compact nor cheap. The value is in having a precise, pre-built, sealed module that you can plug/solder into a larger board.
  • \$\begingroup\$ Do you know which component manufacturers are big on resistor networks? \$\endgroup\$
    – BeB00
    Commented Aug 16, 2017 at 18:55
  • \$\begingroup\$ @BeB00 I have no experience here, but that sounds like a question to answer starting by seeing who makes the resistor networks available at your favorite component supplier (e.g.). \$\endgroup\$
    – Kevin Reid
  • \$\begingroup\$ With resistor networks it looks like the smallest are basically just a line of 0201 resistors in one package, so theres no space saving. \$\endgroup\$
    – BeB00
    Commented Aug 16, 2017 at 19:02
  • \$\begingroup\$ May be worth mentioning that thin-film resistor value tolerance tends to be very loose, but the resistor ratios can be very precise. (Ohms per square sheet resistance is a process variable, but number of squares in a design element only depends on lithographic accuracy.) So it can make sense to build a resistor divider network, but replacing unrelated discrete resistors may not work as well. \$\endgroup\$
    – MarkU
    Commented Aug 16, 2017 at 20:44
  • \$\begingroup\$ @MarkU That's what I was getting at by saying "matched", but I've put in a few more words on that. \$\endgroup\$
    – Kevin Reid
    Commented Aug 16, 2017 at 20:52
12
ASIC means Application Specific Integrated Circuit. If that integrated circuit would contain only passive components then we could still call it an ASIC.
Making a silicon die with only passive components is very well possible but there are severe limitations. On an IC capacitors are only practical up to a few nF. Inductors can only be a few nH. Resistors can be made in almost any value.
These passive components (except for the inductors) might have parasitic diodes to the substrate so it is possible that they're not 100% passive.
Designing and producing an ASIC is never cheap. Depending on the manufacturing process, making the masks (needed to define the patterns to make the components) can be anywhere between $ 10000 to $1000000 (yes, on million US dollars).
The actual cost of producing one IC once you have the masks is lower, it can be a few cents each up to tens of dollars depending on the size (smaller size cheaper). But with a high mask cost you'd need to make many of these chips (and use/sell them) for this to be cost effective. The mask cost is shared between all the ICs you produce so the more the better.
I worked at Philips Semiconductors in the past and they had a special process for passives only. The idea was that these ICs would provide the supply decoupling capacitors and RF matching components for a separate, small IC with the active components and made in a more expensive process technology. This smaller IC would then be mounted on top of the die with the passive components.
This was a bit complicated to produce so it was only used for some niche products as far as I know. It is certainly not mainstream technology.
You don't have to have actives on an ASIC (although I don't know if anyone has ever done this). There are manufacturers who will do this kind of thing, it is expensive and you need large quantities.
There are better ways that would still be more costly than a PCB with components but cheaper than an ASIC. Components can be built inside the PCB.
Source: EDN
Or you can get integrated packages:
These last two would probably be cheaper than an integrated circuit where the passives are built into silicon, however embedding components in these new processes will be much more expensive than using a PCB with micro vias and stacking PCB's
    \$\begingroup\$ I think ASICs are more in the digital domain Not true, I've worked on many ASICs over the years and all of these had a significant part with Analog electronics. Which I partly designed ;-) \$\endgroup\$ Commented Aug 16, 2017 at 19:43
  • \$\begingroup\$ Yeah, in my experience that's what I've heard. I realize its a fuzzy distinction. \$\endgroup\$
    – Voltage Spike
    Commented Aug 16, 2017 at 19:52
  • \$\begingroup\$ Digital/analog has nothing to do with it being an ASIC. ASICs these days usually have analog front-ends and digital internals. But there's no reason you couldn't have it be entirely one or the other. They're simply orthogonal ideas. \$\endgroup\$
    – horta
    Commented Aug 16, 2017 at 19:58
  • \$\begingroup\$ Look, in every case I've heard it ASIC had to do with digital and IC with analog. I'm telling you what I've been told I didn't say it was right. \$\endgroup\$
    – Voltage Spike
    Commented Aug 16, 2017 at 20:03
    \$\begingroup\$ I think we're just suggesting you remove that wording from your answer so that it doesn't further confuse readers of your otherwise good answer. \$\endgroup\$
    – horta
    Commented Aug 16, 2017 at 20:15
Yes, definitely. Here at Keysight, for example, we do create some of our own basic strip-line filters for probes and other equipment. Building passive components into chips is standard.
Other clarifications. ASIC vs. IC - If you're designing a chip for a specific purpose, then the "AS" is valid. It's a potato/potahto situation.
Digital vs. Analog? - Both are common. Digital ASICs generally do processing and computations, analog ASICs generally massage a signal into a more usable form. We talk about this one on the EEs Talk Tech electrical engineering podcast here:
https://eestalktech.com/2017/07/13/fast-adc/
