After reading the excellent article on bare metal by David Welch (https://github.com/dwelch67/raspberrypi/tree/master/baremetal), a friend and I are trying to implement a simple GPIO toggle. It's built on David Welch's blinker01 (https://github.com/dwelch67/raspberrypi/tree/master/blinker01). I simply updated the peripheral registers to correspond to GPIO 3 on the raspberry pi. I found these addresses by looking through the BCM2835 data sheet (https://www.raspberrypi.org/app/uploads/2012/02/BCM2835-ARM-Peripherals.pdf). Chapter 6 lists all the locations of the GPIO pin settings.
We load the code onto an SD card and then power up. The program works: we get a 2.5MHz square wave on the scope.
** Why is it so slow? **
The processor has a clock speed of 1 Ghz. The operation we implemented loops 10 lines of assembly (i.e. does 10 lines of assembly then branches back to the first line of those 10). I'm new to bare metal/processors and I understand that a given line of assembly can take several clock cycles. Assuming each line takes 10 clock cycles, I would still expect a 100ns period for the output, which would be 10MHz. I feel that is a conservative lower bound on the output frequency, since some assembly lines only take a single cycle.
Furthermore, I found this article: http://codeandlife.com/2012/07/03/benchmarking-raspberry-pi-gpio-speed/
This person managed to get a 22MHz output on a raspberry pi 1 using a similar approach but using linux' mmap. The code that they used as a base is located as the first example on this page: http://elinux.org/RPi_GPIO_Code_Samples
** Edit: I originally thought that the 22MHz was achieved on a raspberry pi 2, but that is incorrect. They state that they achieved this output rate on a pi 1 which has the BCM 2835 chip in it **
Note: Although this debatably belongs on StackOverflow, I felt that it's a "harder" problem in that it has to do with the circuitry in the processor and the peripherals.
Edit: Assembly code is here: Disassembly of section .text:
00008000 `<_start`>:
8000: e3a0d902 mov sp, #32768 ; 0x8000
8004: eb000005 bl 8020 <notmain>
00008008 `<hang`>:
8008: eafffffe b 8008 <hang>
0000800c `<PUT32`>:
800c: e5801000 str r1, [r0]
8010: e12fff1e bx lr
00008014 `<GET32`>:
8014: e5900000 ldr r0, [r0]
8018: e12fff1e bx lr
0000801c `<dummy`>:
801c: e12fff1e bx lr
00008020 `<notmain`>:
8020: e92d4010 push {r4, lr}
8024: e59f002c ldr r0, [pc, #44] ; 8058 <notmain+0x38>
8028: ebfffff9 bl 8014 <GET32>
802c: e3c01c0e bic r1, r0, #3584 ; 0xe00
8030: e3811c02 orr r1, r1, #512 ; 0x200
8034: e59f001c ldr r0, [pc, #28] ; 8058 <notmain+0x38>
8038: ebfffff3 bl 800c <PUT32>
803c: e3a01008 mov r1, #8
8040: e59f0014 ldr r0, [pc, #20] ; 805c <notmain+0x3c>
8044: ebfffff0 bl 800c <PUT32>
8048: e3a01008 mov r1, #8
804c: e59f000c ldr r0, [pc, #12] ; 8060 <notmain+0x40>
8050: ebffffed bl 800c <PUT32>
8054: eafffff8 b 803c <notmain+0x1c>
8058: 20200000 eorcs r0, r0, r0
805c: 2020001c eorcs r0, r0, ip, lsl r0
8060: 20200028 eorcs r0, r0, r8, lsr #32
