I am working on a project with the STM32F411 microcontroller. It is set in SPI slave mode and receives data without any problems. When I want to send data over the SPI peripheral works sometimes but most of the time the bits I am trying to send a shifted or there is wrong data sent. I have configured the SPI peripheral like it was shown in an example in the standard peripheral drivers for this controller, and I also don't have a chip select line because I only have one slave in the system.
Is there something wrong in my setup or do I refill the tx buffer at a wrong moment?
Here is my code:
void spi1_init(){
SPI_InitTypeDef SPI_InitStruct;
spi1_gpio_init();
// Enable the SPI periph clock
RCC_APB2PeriphClockCmd(RCC_APB2ENR_SPI1EN, ENABLE);
// Set data size to 8b
SPI_InitStruct.SPI_DataSize = SPI_DataSize_8b;
SPI_I2S_DeInit(SPI1);
SPI_InitStruct.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_64; // 100MHz / 64 = 1.5625MHz
SPI_InitStruct.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStruct.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStruct.SPI_Mode = SPI_Mode_Slave;
SPI_InitStruct.SPI_NSS = SPI_NSS_Soft;
SPI_InitStruct.SPI_CRCPolynomial = 7;
// Mode 0
SPI_InitStruct.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStruct.SPI_CPHA = SPI_CPHA_1Edge;
// Init SPI
SPI_Init(SPI1, &SPI_InitStruct);
spi1_interrupt_init();
// Enable the SPI peripheral
SPI_Cmd(SPI1, ENABLE);
void spi1_gpio_init(void){
GPIO_InitTypeDef GPIO_InitStruct;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_SPI1);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_SPI1);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_SPI1);
GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_DOWN;
GPIO_InitStruct.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_3;
GPIO_Init(GPIOB, &GPIO_InitStruct);
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStruct.GPIO_Pin = GPIO_Pin_5;
void spi1_interrupt_init(void){
NVIC_InitTypeDef NVIC_InitStruct;
// Configure the SPI interrupt priority
NVIC_InitStruct.NVIC_IRQChannel = SPI1_IRQn;
NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 1;
NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0;
NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStruct);
// Enable the Rx buffer not empty interrupt
SPI_I2S_ITConfig(SPI1,SPI_I2S_IT_RXNE,ENABLE);
// Enable the Tx empty interrupt
SPI_I2S_ITConfig(SPI1, SPI_I2S_IT_TXE, ENABLE);
void SPI1_IRQHandler(void)
int8_t CmdReceived;
static uint32_t CmdCount = 0;
static int8_t RecArray[SPI_REC_BYTES];
static uint32_t dataCounter = 0;
// SPI in Transmitter mode
if (SPI_I2S_GetITStatus(SPI1, SPI_I2S_IT_TXE) == SET)
SPI_I2S_SendData(SPI1, 123);
// SPI in Slave Receiver mode---------------------------------------
if (SPI_I2S_GetITStatus(SPI1, SPI_I2S_IT_RXNE) == SET)
CmdReceived = SPI_ReceiveData(SPI1);
if(CmdReceived < -100){
CmdCount = 0;
RecArray[CmdCount] = CmdReceived;
} else if(++CmdCount < SPI_REC_BYTES){
if(CmdCount == (SPI_REC_BYTES-1)){
callbackfunction(RecArray);
callbackfunctionin your case) may be better executed asynchronously in the main loop upon being signalled from the ISR that it's time to do so. \$\endgroup\$
