-4
Need help to find out this datasheet or similar model parts that can i replace with this...???
i have have a problem with this transistor...this transistor front pin broken from body i want to replace it but i did not find out any salutation .....
its marking code is wrote in up ( N1Z5 ) that u see in the picture... i did not find it any where can any one help me to find its datasheet or similar one that can i replace with this ???1]
    \$\begingroup\$ need help argent??? \$\endgroup\$ – Agent 007 Aug 18 '17 at 11:29
  • \$\begingroup\$ From whatever I searched, it might be an N-channel FET, not sure though. Couldn't find the exact model. \$\endgroup\$ – Sachin Aug 18 '17 at 12:25
    \$\begingroup\$ "need help argent???" If you want urgent help then you pay someone. We will answer if we want to, when we want to. Please have some respect. \$\endgroup\$ – Transistor Aug 19 '17 at 10:40
  • \$\begingroup\$ I found that model on website but i dont understand will u see it bro?? @Sachin ...ic-smd.com/stk/page/1/1HC1-3_11254.html \$\endgroup\$ – Agent 007 Aug 19 '17 at 11:12
    \$\begingroup\$ @Agent007 we're not your "bros". We're strangers on the internet who are trying to help. Please handle us with a bit of respect, and also, patience. You must also understand that your question is very vague. \$\endgroup\$ – Marcus Müller Aug 19 '17 at 13:18
It's a MOSFET
From the codebook data I've been able to find, it's a P-channel MOSFET, either a Vishay Si2301CDS or an APEC AP2301GN. The two parts have roughly comparable specs and are pin/package compatible, so I'd give the Si2301CDS a whirl in the application.
  • \$\begingroup\$ Brother Can I replace Si2301CDS this model with the top of ??? \$\endgroup\$ – Agent 007 Aug 19 '17 at 6:55
  • \$\begingroup\$ @Agent007 -- are you asking if you can use the Si2301CDS as a replacement or if you can substitute something else for it? \$\endgroup\$ – ThreePhaseEel Aug 19 '17 at 14:24
  • \$\begingroup\$ Yes sir....can i replace (Si2301CDS) Or (AP2301GN) Instead of pic (N1Z5) mosfet ??? @ThreePhaseEel \$\endgroup\$ – Agent 007 Aug 22 '17 at 16:41
  • \$\begingroup\$ @Agent007 -- that's what I'm saying, yes. Try the Si2301CDS first, it should be easier to get. \$\endgroup\$ – ThreePhaseEel Aug 22 '17 at 22:11
  • \$\begingroup\$ Thanx a lot sir... \$\endgroup\$ – Agent 007 Aug 23 '17 at 14:36
