I am designing a circuit containing two Atmega328p. First chip will drive TFT screen with 3.3 V linear voltage reg.
Second one will drive BT module, couple of relays, two sensors, SD card module, and will pass data do first chip to display.
The circuit will be powered by wall charger. Is it okay to use LM2596 buck converter module to get 5 V needed for microcontrollers or should I go for the linear voltage regulator. I am worried about the noise that SMPS can cause, but I am concerned about power consumption as well, since circuit will be ON 24/7. Only TFT will be powered on occasionally.
