Are you really saying that you have a 220 V supply that intermittently gives 440 V? How does anything electrical survive in your location?
You can't series connect two primaries on different cores like that unless you parallel the secondaries. Let's think about why:
Figure 1. (a) Due to different secondary currents the primary impedances will not match. (b) and (c) will work because the secondary currents will be the same, therefore the primary impedances and currents will be the same.
- A transformer's primary current will depend on it's secondary current (which will vary with the load). \$ \frac {N_P}{N_S} = \frac {I_S}{I_P} \$ where N is the number of turns, P is primary, S is secondary and I is current.
- With no secondary current a transformer's impedance (AC resistance, if you like) is quite high - otherwise a high current would flow.
- On the transformer with secondary current the primary impedance would be lower.
- It should now be clear that you no longer have half the supply voltage on each primary. The one that is loaded will have a much lower voltage.
Connecting the secondaries in series or parallel ensures that both secondaries pass the same current and the primary impedances will match.
This only gives you enough theory to understand why your proposed solution is poor. You need to fix your incoming power supply.
Impedance
I don't quite understand how impedance of transformer will have to change?
Given that \$ Z_P = N^2 Z_S \$ where \$ N \$ is the turns ration we can see that
if a seconday is open circuit then Z is infinity on both sides of the transformer.
I think the connection shown in Fig. 1a will induced voltage tending to infinity across secondary, similar to case in current transformers.
It would if you could force current through the primary. You can't however. You only have your mains voltage and an infinite impedance. The primary of XFMR2 will appear to be an open-circuit to an AC supply. No current will flow. Full mains voltage will be across XFMR1 primary and XFMR1 secondary will have a voltage \$ \frac {1}{N} \$ times that.
Remember that we're dealing with ideal transformers for this discussion. Real ones will have some losses and leakage so the impedance will not be infinite.
