I bought a cheap china tablet and it worked fine for a few weeks. Yesterday while charging and using at the same time it got warm. I opened it and recharged the battery manually and it worked again. But it is not accepting any change through the USB port. Today I took a more closer look and found one IC was burned. The tablet is a BS109.
Is is possible to know what this chip could be? I'm guessing some voltage regulator, since voltage at battery +/- should be 4.x Volts and now only is 2.5 Volts. I see only a 4 then a burned hole and a 0 and a 3 (4?03). On row 2 I guess it is year and week. On another picture I think I see 4C03
Update. On a similar tablet I found that the chip is marked 4603
