Suppose that I have designed an electrical digital circuit that contains only resistors, transistors, capacitors and diodes to implement some electrical device, but it contains many instances of these four electronic components that makes the electrical circuit complex, difficult to produce and this also makes the production of the electrical circuit and the electrical device too expensive.
Do already exist methods to minimize, reduce and simplify electrical circuits with only resistors, transistors, capacitors and diodes so I can implement the same electrical circuit, with same inputs, outputs and behavior with lesser and minimal number of these four electronic components?
If the methods exist then what are they then?
Can someone please give me reference to webpages that explain these methods in simple english and physics words?
