I would like to build a control panel to direct K power sources to N loads. A power source can control any number of loads, but a load can only be connected to a single power source. Each power source is variable (0 to 16V at up to 2A).
In a purely mechanical version, I imagine using a K+1 rotary switch for each load, where "+1" represents a no-power-source state.
I would like to implement this with a minimal set of small pushbuttons. I imagine a multiplex-like setup of pushbuttons as follows: each power source is represented by a pushbutton; each load is represented by a pushbutton. When a pair of pushbuttons(source,load) is pressed, the load is powered by source.
I've put together a circuit with AND gates to represent each pushbutton(source,load) combination; latches to hold state; and a grid of transistors to connect variable power sources (P1, P2, ..) to loads (targets 1, 2, ..). A separate constant power source Pc is used for the circuitry.
Design proposal for circuit to control K power sources to N loads
Missing from the diagram is reset logic which would ensure that at most one power source is connected to a load. Also missing is logic for the no-power-to-load option, which I imagine could be a P(zero) pushbutton.
I am seeking input to this design. Am I missing something substantial? Have I oversimplified the problem? Working with multiple power sources, does this circuit create undesired effects?
Thank you.
  • \$\begingroup\$ Is there a reason you wish to do this with discrete parts? \$\endgroup\$ – ThreePhaseEel Aug 21 '17 at 2:15
  • \$\begingroup\$ No particular reason beyond that this is all I could think of. What alternative do you have in mind? A design choice I'd like to stay away from is PICs and other software-based solutions, primarily because I feel that such solution is overly complex for what I consider to be a mundane switching problem. \$\endgroup\$ – Cosmo Jetz Aug 22 '17 at 17:10
First, I don't think you need source buttons, but eliminating them actually increases the number of buttons. What you have is a SSAD (Source Select At Destination) routing switcher, but for power instead of video or audio.
For a 4x4 array, each output has 4 buttons, one for each input. Pressing any button latches 4 bits, and since only one button is pressed at a time, the latch for that output line holds one 1 and three 0s. If the latch outputs are negative-true, then PNP power transistors will make efficient high-side switches.
With only 8 switches, the latch input becomes a bit more complex.
  • \$\begingroup\$ Thanks. I see from another post of yours that you're referring to the 74HC/HCT259 8-bit addressable latch. IIUC, this would replace the LATCH section in my diagram, considering that I retain the (source,load) pair of buttons and the AND gates in section INPUT. Using this 8-bit addressable latch would solve the single-output portion of the design problem. To clarify, does HCT259 work with momentary inputs (such as a pushbutton) while retaining state (pushbutton depressed)? \$\endgroup\$ – Cosmo Jetz Aug 22 '17 at 17:29
