A single phase supply requires 2 wire one for forward and next for returning path. However a 3 phase supply only requires 3 wire why? How does the circuit complete with 3 phase supply?
closed as too broad by winny, Andy aka, PeterJ, Brian Drummond, Voltage Spike Aug 22 '17 at 16:04
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ If memory serves correctly, there are two sorts of three phase. Three wire and four wire. Depends on whether it is star or delta. Ah, yes, a quick Google turns this rather splendid site up: electrical4u.com/three-phase-circuit-star-and-delta-system \$\endgroup\$ – DiBosco Aug 21 '17 at 9:01
  • \$\begingroup\$ Welcome to the EE.SE, you might want to edit your question, give it some structure to make it more appealing and attract quality answers. \$\endgroup\$ – Sclrx Aug 21 '17 at 9:18
The return path for one phase is one or both of the other phases.
Loads can be connected "delta" - wired between the phases (L1 to L2, L2 to L3 and L3 to L1).
Alternatively, a star point can be created, and the loads star wired (L1 to S, L2 to S, L3 to S). In a 4-wire 3-phase system, the star point would be connected to neutral. However, if all three loads are identical, it turns out that the current in the neutral is zero, and so it can be left out entirely.
In a single phase system, current is balanced between the line and neutral conductors.
In a three phase system, current is balanced between the three conductors. This is possible due to the phase angle difference between the phases.
