It is very unlikely that your system is configured as shown in your schematic. With the leftmost active pot wiper fully left you short out the voltage reference.
Figure 1. (a) A more likely arrangement in your rhythm box. (b) Dividing the output by two. (c) Dividing the input by two.
- (a) shows the likely arrangement. Note that the load on Vref remains constant no matter where the wiper is set. (This assumes that the load on OUT is fairly high resistance so that it doesn't load Vref significantly.)
- (b) divides the output voltage by two. Since your downstream circuit will have some loading effect you may find that this does not quite give you half the frequency. R3 and 4 need to be about ten times the pot resistance value to avoid loading it too much or the voltage will droop.
- (c) is very simple. Use the potentiometer resistance track as half of a potential divider. This should be the simplest to implement too. It may just require cutting the track to the "top" of the pot and adding the series resistor and single-pole, single-throw switch.
Your modified schematic still shows series connected variable resistors. You have forgotten to connect the wipers to one end of the pots. At the moment they do nothing as they are open circuit.
Figure 2. Stereo potentiometer arrangements. (a) What the OP intends. (b) This circuit will not work in the OP's application.
- Figure 2a will only work if the original potentiometer is wired not as a potentiometer but as a variable resistor or "rheostat". This may be the case but is unlikely. Note that you can simplify this further by simply shorting out one of the pots using an SPST switch rather than an SPDT type.
- Figure 2b will not work as the result would be a square-law. Fully clockwise the output would be 100%. At mid-position the output would be 50% x 50% = 25%.
To resolve your problem you need to reverse engineer the circuit to understand how the original potentiometer is being used.
Your latest edit shows you had the schematic all along. Oh, man!
Figure 3. The resistor solution based on the original design.
We can see from this that it is a heap of trouble. @KevinCathcart's solution is the way to go.
