I'm using an STM32F103C8T6 (aka blue pill).
GPIO Init and interrupt handler:
static void MX_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct;
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOD_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_13, GPIO_PIN_SET);
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_15, GPIO_PIN_RESET);
/*Configure GPIO pins : PC13 PC15 */
GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_15;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
/*Configure GPIO pin : PA0 */
GPIO_InitStruct.Pin = GPIO_PIN_0;
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
HAL_NVIC_EnableIRQ(EXTI0_IRQn);
while(1);
void EXTI0_IRQHandler(void)
__HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_0);
HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_14);
The problem is that the interrupt handler (EXTI0_IRQHandler) is never called. I tried also with other pins (e.g. using EXTI15_10_IRQHandler). I checked the switch and LED separately (in the main function) and those work. I also tried with PULLUP and PULLDOWN (which makes no difference).
Is there more needed to trigger the interrupt function?
EXTI0_IRQn
a constant or should it be something likeEXTI0_IRQ0
? \$\endgroup\$ – Marcus Müller Aug 21 '17 at 21:04
