So far I have:
float temp = 22.45;
Serial3.print(temp + "\r");
I knew that code would not work from the getgo.
I am attempting to concatenate the temp variable and a carriage return. The board that I will be communicating with will only accept a carriage return at the end and not a new line, otherwise I would have used a println(). How do I combine the float value and a carriage return and send it via Serial3?
EDIT
char tempAr[10];
String tempAsString;
String serialData;
dtostrf(temp,1,2,tempAr);
tempAsString = String(tempAr);
serialData = tempAsString + "\r";
Serial3.print(serialData);
The above code seems to work; however, it is still rough around the edges and I will have to change the width and precision values in the dtostrf per decimal place(ones, tens, hundreds);
    \$\begingroup\$ Couldn't you send one after the other? Something like: Serial3.print(temp); Serial3.print('\r'); \$\endgroup\$
    – bjthom
    May 24, 2012 at 17:52
  • \$\begingroup\$ I tried that approach, but I did not get a response. \$\endgroup\$
    – dottedquad
    May 25, 2012 at 0:33
  • \$\begingroup\$ You might want to take a look at the update in my answer for a more convenient and efficient function \$\endgroup\$
    – nijansen
    May 25, 2012 at 12:28
The comment by bjthom seems very straightforward, but if that is not an option for you, how about sprintf?
float const val = 22.45;
char buf[64];
sprintf(buf, "%f\r", val);
Serial3.print(buf);
Update
You are right, sprintf is a potential bottleneck. Here is a far more efficient function that gets you around the usage of the String class:
char * ftoa_wr(float f, char * a, int precision=2)
  char * const ret = a;
  long const bp = (long)f;
  itoa(bp, a, 10);
  while(*a != '\0') a++;
  *a++ = '.';
  long const ap = abs(
    (long)(
      (f - bp) * pow(10, precision)
  itoa(ap, a, 10);
  *a++ = '\r';
  return ret;
With it you could do
char buf[10];
Serial3.print(ftoa_wr(22.45, buf));
  • \$\begingroup\$ I remember using this trick +1 \$\endgroup\$
    – jippie
    May 24, 2012 at 19:25
  • \$\begingroup\$ After researching sprintf some more, I found out sprintf does not work efficiently. I edited my original post with an approach that seems to be working. \$\endgroup\$
    – dottedquad
    May 25, 2012 at 0:34
