In order to define the transfer function of an EMI filter, I want to know if I need to define the equivalent circuit in CM and in DM to calculate the total transfer function of the filter below:
  • \$\begingroup\$ Hi Nicolas! I must admit that I don't know what "CM" and "DM" are, but that might be because English is not my native language. Why do you use the high-voltage tag? Is there something specifically high-voltage about this circuit? \$\endgroup\$ – Marcus Müller Aug 22 '17 at 21:31
  • \$\begingroup\$ @MarcusMüller Probably CM = common mode, DM = differential mode. \$\endgroup\$ – Andreas Aug 22 '17 at 21:45
  • \$\begingroup\$ Hi Nicolas. An EMI filter will contain chokes, not inductors. These will exhibit nonlinear behaviour. Trying to tackle this with filter theory may be the wrong method. \$\endgroup\$ – Andreas Aug 22 '17 at 21:49
  • \$\begingroup\$ @Andreas Yes it a chokes just i dont find a chokes in PSIM \$\endgroup\$ – Nicolas Aug 22 '17 at 21:54
    \$\begingroup\$ @Nicolas I do not know much about simulation. You may want to read though this. Transfer functions are used to characterize linear time-invariant systems, so you questions title may be misleading. \$\endgroup\$ – Andreas Aug 22 '17 at 22:10
