-1
I have set of data that i want to send them via h-05 Bluetooth module.But data has variable baud rate and i don't know the baud rates.How can i do it?Is there any Bluetooth module that don't care to data baud rate and just send what in its RX pin? For example if it has 1 in its RX pin for 2 seconds, The module sends 1 for 2 seconds and so on and so forth just like max-232 module.How can i do this?
  • \$\begingroup\$ Bluetooth modules and MAX232 modules are completely different beasts, you cannot think of them in the same way. Why do you think you will not know the baud rate of the HC05? \$\endgroup\$ – DiBosco Aug 23 '17 at 9:48
  • \$\begingroup\$ I know the baud rate of HC-05 but the data that i want to send via this module has a variable baud rate during send period. \$\endgroup\$ – Z.Dasy Aug 23 '17 at 17:41
  • \$\begingroup\$ I do not understand what you mean, sorry. \$\endgroup\$ – DiBosco Aug 24 '17 at 7:51
