I am designing a PCB with KiCAD where components such as SMD resistors and capacitors are placed before and after DC/DC converters.
I am trying to build two different common grounds: one placed on the left side of the PCB (for all the input signals) and another one placed on the its right side (for all the output signals).
In order to do so, I am placing ground traces in the B.Cu layer and the rest of them in the F.Cu layer. Then, in the B.Cu layer, I am drawing two separated filled zones -which are connected to their corresponding ground traces-, one on the left, and another one on the right.
PCB design
For doing that, I need to place one of the pads of the SMD component in the B.Cu layer (the "ground pad") and the other pad must be placed in the F.Cu layer (the "VCC pad"). The pads of the SMD components are by default both placed in the F.Cu layer.
However, I can edit the properties of the component's "ground" pad, select its layer to be B.Cu, and select B.Paste and B.Mask as technical layers.
If I do so, when looking at the 3D design of the PCB, I notice that the copper for the "ground pad" on the top layer (F.Cu) does not exist. Of course, SMD components can only be soldered to one layer, and thus, I need the top layer to have copper for both pads.
The way I have found to solve this is to select both F.Paste and F.Mask as well as B.Paste and B.Mask in the technical layers list for the component's "ground pad". I reckon that this means that I will be able to solder the component on the top layer, and the VCC pad copper will go down just to the first layer (F.Cu), while the GND pad copper will go down to the bottom layer (B.Cu), thus solving my problem.
Pad properties example
Is this correct? I am solving this implementation issue properly?
    \$\begingroup\$ How do you make the connection through the board? SMD pads don't have plated holes to make a connection through the board. I'd leave both pads on the same layer, and place a via close to the ground pad to make the through-board connection. \$\endgroup\$ Aug 23, 2017 at 16:07
It is not correct to play around with the SMT pads like you are trying to do. The component pads, solder masking and paste masking for those SMT device pads all need to be on the same layers. Just because you can edit a pad to be on some other layer does not automatically make it be connected by some magic.
When SMT devices need to connect to other layers the way to do that is with a plated hole via. For traces that are meant to connect GND or PWR plane areas often multiple vias are used to lower the connection resistance and inductance. This can be important because often the vias are the smallest holes on the board and do not represent a lot of layer transition copper. THe holes are often smaller than the thickness of the board itself.
You can't put SMD pads on different layers. You also can't put SMD pads on inner layers. SMD pads can only be on the top or bottom metal.
Build your SMD part with pads all on top metal, then use vias to connect on board level layout.
"Of course, SMD components can only be soldered to one layer, and thus, I need the top layer to have copper for both pads."
Yes, that is exactlyl right. One physical SMD component can only be soldered to one layer, either the front (F.Cu) or the back (B.Cu).
So after you place the SMD footprint on the top layer, both "pads" are already on the top metal layer, just as they should be.
"For doing that, I need to place one of the pads of the SMD component in the B.Cu layer (the "ground pad") and the other pad must be placed in the F.Cu layer (the "VCC pad").
The way to get the GND pad of your capacitor connected to stuff on the bottom layer is by adding a trace to make that connection.
Once in KiCad's PCB Editor, Hit "x" to start routing a trace, click on the GND pad of your capacitor, click a few more times to draw a trace (on the F.Cu) out from your capacitor. While you are running a track, hit "v" to switch to the back layer (placing a via), then click a few more times to draw a trace (on the B.Cu). (Ideally you would eventually click on some other pad connected to GND, even if that meant hitting "v" again on to switch back to the front layer).
Every KiCad tutorial should cover routing a trace. Find one that makes sense to you, perhaps one of:
