-2
To calculate battery's energy, one should use the nominal voltage or 100% SOC voltage?
Nominal voltage. The battery voltage drops fairly quickly from 100% SOC so you would definitely get an over-estimate if you used the 100% charged voltage.
Nominal voltage is where the battery spends most of its time in the discharge curve.
Very rough calculation for 12V 100Ah:
$$W = P\cdot t = 12\cdot 100\cdot 3600\cdot V\cdot A\cdot s= 4320000 Ws=4320000J \approx 4MJ$$ Like 0.1 litre of gasoline.
