As the title, I'm trying to measure and display 230VAC voltage and current from a DC/AC inverter on an oscilloscope. I don't know if I can proceed to measure them directly with these equipment:
-Oscilloscope: Tektronix TPS 2014b
-Differential Probe: TT-SI 9001 with the range of +-700V at 1/100 (CAT 3 1000 Vrms)
-Current Clamp: Fluke i30s with max current of 20 Arms
The inverter is pure sine Phoenix inverter 12|250. Power: 250VA and Peak power of 400W.
    \$\begingroup\$ What is your question? \$\endgroup\$ – Andy aka Aug 25 '17 at 10:52
  • \$\begingroup\$ sorry for not stating it out. The question is: Can I proceed to measure with such equipment? \$\endgroup\$ – Kha Truong Aug 25 '17 at 11:00
    \$\begingroup\$ Because measuring and displaying AC on an oscilloscope usually need some protection such as isolation transformer or a voltage divider. However, because I also have the mentioned probes, I don't know if I can measure the output directly on the oscilloscope via these probes. \$\endgroup\$ – Kha Truong Aug 25 '17 at 11:12
  • \$\begingroup\$ Show schematic. \$\endgroup\$ – winny Aug 25 '17 at 14:14
