I'm trying to find a way to translate small angle rotation into some form of digital signal. 1 degree resolution would be excellent, but something like 5 degrees would be ok.
I need something like a rotary encoder, but with much higher resolution, similar to what we see inside old rubber ball mouses, which have an encoding disk and IR leds/sensors to detect when the disk spins.
Is there any commercial component that would do that? Or I will need to build it myself?
Thanks in advance!
    \$\begingroup\$ resolution of rotary encoders is expressed in pulses per rotation, you need something above 72 (5° per pulse) or 360 (1° per pulse). A quick google showed me several with 1024 p/r. \$\endgroup\$ Aug 25, 2017 at 13:09
  • \$\begingroup\$ @ratchetfreak, thank you! I didn't know about the PPR parameter, this is the key to find these encoders. \$\endgroup\$ Aug 25, 2017 at 13:13
Resolution of rotary encoders is expressed in pulses per rotation. One rotation being 360°.
In your case you need something above 72 (5° per pulse) or 360 (1° per pulse).
