I purchased this cigarette lighter unit that is a voltage meter, temperature sensor, and USB charger. The temperature sensor appears to be on a wire lead that comes out of the case.
I took apart the unit and its construction is very simple. I can solder to the circuit board if need be. What type of thermistor does this unit likely use? How far can I extend the leads of the temperature sensor and have the unit continue to give an accurate reading?
| improve this question | | | | |
  • \$\begingroup\$ Are you sure it's a thermocouple and not a thermistor? (Measure its resistance.) \$\endgroup\$ – ThreePhaseEel Aug 26 '17 at 15:56
In a consumer product such as this, the "thermocouple" is "likely" to be a thermistor. A thermistor are just a temperature sensitive resistor, so you can solder extension wires to it without any adverse effect. Their resistance is normally in the kilo-ohm range, so don't worry about the resistance of the wires.
| improve this answer | | | | |
