I would like to know the altera quartus primitive equivalent to the FDCE flip flop on Xilinx ISE. I think that DFFE primitive might work however I am not sure about the CE and CLR pins equivalency. Also the PRN pin confuse me. I have included a link to the altera documentation that I have been using so far.
http://quartushelp.altera.com/14.1/mergedProjects/hdl/prim/prim_pu_pinstub_names.htm
    \$\begingroup\$ Why do you need a primitive? Can't you write it as portable, generic VHDL or Verilog code? \$\endgroup\$ – Paebbels Aug 27 '17 at 9:00
  • \$\begingroup\$ I am pretty sure that will be a right solution. But at this point I am trying to map features between the two IDEs for educational reasons. \$\endgroup\$ – artificer Aug 27 '17 at 19:29
Newer versions of Quartus have wrappers for different basic flip-flop types. A list of all primitives can be found here: Primitive List for Quartus 15
Here is the DFFE component:
COMPONENT DFFE
  PORT (
    d    : IN  STD_LOGIC;   -- Data input
    clk  : IN  STD_LOGIC;   -- Clock
    clrn : IN  STD_LOGIC;   -- Clear (Reset, low-active)
    prn  : IN  STD_LOGIC;   -- Preset (low-active)
    ena  : IN  STD_LOGIC;   -- (Clock) Enable
    q    : OUT STD_LOGIC    -- Data output
END COMPONENT;
Source: http://quartushelp.altera.com/15.0/mergedProjects/hdl/prim/prim_file_dffe.htm
Outdated Altera documentation:
There is the Quartus Low Level Primitive Guide.
Here is the basic flip-flop cell:
COMPONENT DFFEAS
  PORT (
    d      : IN  STD_LOGIC;
    clk    : IN  STD_LOGIC;
    prn    : IN  STD_LOGIC;
    ena    : IN  STD_LOGIC;
    asdata : IN  STD_LOGIC;
    aload  : IN  STD_LOGIC;
    sclr   : IN  STD_LOGIC;
    sload  : IN  STD_LOGIC;
    q      : OUT STD_LOGIC
END COMPONENT;
Quartus has only one primitive, whereas Xilinx offers different wrappers for the same primitive.
