Who knows what K63 means? I think it comes from an old Philips CRT.
It looks like a blue capacitor It says: N47K63
I think N47 stands for 47 nanoFahrad, but what can K63 mean?
    \$\begingroup\$ N47 usually does not mean 47 nF, but 47K can mean 47000 pF which is 47 nF, 63 means 63 Volts. So My guess is that this is a 47 nF, 63 V capacitor. I'd use an MKT model if it needed to be replaced. \$\endgroup\$ Aug 27, 2017 at 13:45
  • \$\begingroup\$ @Bimpelrekkie Thank you ... I don't need to replace it, the CRT was fully dead. It's my first salvage project and just don't recognize all components (so I learn by asking what it is). I couldn't find it by searching on google. \$\endgroup\$ Aug 27, 2017 at 13:49
  • \$\begingroup\$ @Bimpelrekkie -- make that an answer and I'll upvote it \$\endgroup\$ Aug 27, 2017 at 13:52
  • \$\begingroup\$ @Bimpelrekkie I will upvote it too of course, your remark is exactly the answer. \$\endgroup\$ Aug 27, 2017 at 13:54
N47 usually does not mean 47 nF, but 47K can mean 47000 pF which is 47 nF.
63 means 63 Volts maximum voltage. Since it is not written that that is AC, assume it is DC so the maximum voltage is 63 V DC. Although that sounds like an odd value, it is often used.
