7
This component I think I got it from a CRT television (but also might come from a VGA card, sorry for not remembering).
It looks like a capacitor, but it does not have any Fahrad mentioning.
14
It is a fuse, rated at 1-1/4A 250VAC.
Specifically a slow-blow Littelfuse 372 series.
The marking looks like:
T1,25A250V
That fits with a Time delay (i.e. slow blow) 1.25A 250V fuse.
Assuming that it hasn't blown, it should measure as a (near) short-circuit when you use a multimeter to measure its resistance.
    \$\begingroup\$ I measure indeed around 0.7 or 0.8 ohm \$\endgroup\$ Aug 27, 2017 at 14:47
    \$\begingroup\$ Just a side note: household DMMs are entirely inaccurate for measuring shorts or near-shorts using the resistance setting. In other words, your 0.7/0.8 Ohm reading could have well over 100% error (or more) when measuring very small resistances. Ignore this comment if you didn't actually use a DMM to make that resistance measurement. \$\endgroup\$
    – Dan Laks
    Aug 27, 2017 at 19:47
    \$\begingroup\$ @DanLaks While you are correct, a ~0.7 ohm reading is more than enough to confirm that the fuse is not blown, unless you specifically suspected it was faulty for some reason. \$\endgroup\$
    – nitro2k01
    Aug 28, 2017 at 5:27
  • \$\begingroup\$ @nitro2k01 completely agree. Just wanted to throw in that little factoid in case the OP thought the resistance value was accurate. The fuse is definitely not blown, but we don't know the exact resistance across it (except that it's very small). \$\endgroup\$
    – Dan Laks
    Aug 28, 2017 at 5:31
    \$\begingroup\$ @DanLaks useful to know, thanks. Also: '"factoid": an item of unreliable information that is reported and repeated so often that it becomes accepted as fact.' \$\endgroup\$
    – davidA
    Aug 28, 2017 at 5:47
