I am trying to place a keepout region, however when I go to the Place menu, the options are greyed out and I cannot click on them.
3\$\begingroup\$ Do you have a license checked out? \$\endgroup\$ – The Photon Aug 29 '17 at 0:56
\$\begingroup\$ As Photon said, check for license and if you have license and still facing problem, then reinstall software and check. \$\endgroup\$ – Electroholic Aug 29 '17 at 3:51
\$\begingroup\$ Yes I have a license checked out. All other Altium functionality is working. I have been copy and pasting the same keepout line, and those keepout zones have been working fine, but I may need to use a different keepout zone in the future. \$\endgroup\$ – Shicon Wen Aug 29 '17 at 17:54
You need to select the layer you want the keepout on
2\$\begingroup\$ To be a useful answer, you should add a bit more to it. Give instructions on how to do your solution, and if possible provide screenshots. This will make sure people in the future who are having this problem will be able to solve it \$\endgroup\$ – MCG Dec 7 '18 at 8:14
