I am doing a small code for PIC24FJ1024GB610 from Microchip, where I want to test PORTA
The code Below
#include <xc.h>
#pragma config FWDTEN = OFF
#pragma config FNOSC = FRC
#pragma config ICS = PGD2
unsigned int Pattern;
void Ports (void)
    TRISA = 0x0000;//all outputs
    ANSAbits.ANSA6 = 0;
    ANSAbits.ANSA7 = 0;
    ANSAbits.ANSA9 = 0;
    ANSAbits.ANSA10 = 0;//all digital ports
    LATA = Pattern;
int main (void)
    Pattern = 0xBBAA;
    Ports ();
    while(1);
    return 0;
What I expected to happen was:
  • Pattern is declared as an unsigned int
  • at main () Pattern = 0xBBAA
  • Program calls Ports ()
  • PORTA configured as Output TRISA = 0x0000
  • PORTA is configured as Digital ANSA = 0x0000
  • LATA = Pattern, if I debug the program, I would expect LATA = 0xBBAA in the SFR window.
When I debug the program, and open the SFR window, I get LATA = 0x82AA, as you can see in the screenshot below.
Helpful info:
Any help is appreciated.
You didn't supply a link to the datasheet, so I didn't look it up. My guess is that not all 16 bits of port A are implemented.
Port A pins also are sometimes used for the oscillator pins, the MCLR input, etc. Those aren't available as port A digital pins when those other roles are used.
You really need to read the datasheet.
  • \$\begingroup\$ PIC24FJ1024GA610/GB610 FAMILY - Indeed, not all pins of PortA exist physically. Out of all the ports on a PIC, PortA is typically the most "limited." What is connected to PortD, Adam? That seems to have all 16 pins. \$\endgroup\$
    – rdtsc
    Commented Aug 29, 2017 at 11:14
  • \$\begingroup\$ You guys were right, some pins are removed from the microcontroller. @Olin Lathrop I shall edit, and add a link to the datasheet. Thanks for the help \$\endgroup\$ Commented Aug 29, 2017 at 11:32
