A family member's Bose Wave Music System has stopped responding to its remote control. The battery in the remote control has been changed and I've confirmed that it's emitting a signal (using the "cheap cellphone camera" test). This leads me to suspect that the IR receiver has failed.
I'd like to try replacing it given that the Bose otherwise works properly and initially cost the aforementioned family member a fair amount of money. Even if it hadn't, it seems incredibly wasteful to discard the entire, otherwise-functional system due to the failure of one small, cheap part.
Here's a (rather grainy) photo of the receiver:
IR receiver on the front PCB of a Bose Wave Music System
The package appears identical to this one:
However, I don't know if this package is only used for one particular component or for a family of components with different frequency response characteristics, etc. It matches the package used for Vishay TSOP5038 receiver modules, for example, but is it also used by other manufacturers?
Any information regarding which specific component this might be (perhaps it actually is a TSOP5038) or how I might narrow down the list of possible identities for it would be appreciated!
| improve this question | | | | |
    \$\begingroup\$ There might be a part number on the underside of the component. \$\endgroup\$ – bitsmack Aug 29 '17 at 17:16
    \$\begingroup\$ Before you do anything, I'd suggest probing pins of the device with an oscilloscope while using the remote control. If you see a signal when the remote is operated, you can probably assume the receiver is good and the trouble is elsewhere. \$\endgroup\$ – DoxyLover Aug 29 '17 at 18:26
  • \$\begingroup\$ @bitsmack good point; ideally I'd like to have a replacement before I remove the old receiver, though. \$\endgroup\$ – Reign of Error Aug 29 '17 at 18:49
    \$\begingroup\$ @DoxyLover that's a good idea; I don't have a scope at home, but I suppose I could bring the Bose to work! \$\endgroup\$ – Reign of Error Aug 29 '17 at 18:49
  • \$\begingroup\$ BTW, where I said "device is good", I meant the module. Too late to edit. \$\endgroup\$ – DoxyLover Aug 29 '17 at 22:42
