I'm relatively new with Altium Designer and I'm trying to export a pcb to a STEP model in order to build a chasis in solidworks, but when I export it, there are missing parts. Let the images guide you:
The fisrt is from Altium and the second from Solidworks. When exporting, I have tried this already: 1- Reloading every generic3D models in the pcb library. 2- Every exporting settings or options have been tried. 3- Cried a lot, nothing's changed.
Nothing on the web has helped me yet. Thank you. \ \ EDIT#1:
I have done some changes, corrected all the errors (don't know if it is linked) but now I get this message of error: enter image description here
The problem is that the unsupress button, in the view panel is geryed out... Can't do nothing but do nothing.
    \$\begingroup\$ This is a long shot, but check that the step models are embedded in the footprints. \$\endgroup\$ Aug 29, 2017 at 21:13
  • \$\begingroup\$ Yes, they are all embedded. \$\endgroup\$
    – PyThagoras
    Aug 29, 2017 at 21:38
  • 4
    \$\begingroup\$ Are the vanished parts openable is SW as direct imports? \$\endgroup\$
    – user136077
    Aug 29, 2017 at 22:05
  • \$\begingroup\$ When you export to STEP from Altium did you make sure to check "Export all" (or whatever the actual label is) under the section for mechanical models? \$\endgroup\$
    – DerStrom8
    Aug 30, 2017 at 1:05
    \$\begingroup\$ If your circuit is not secret, consider to provide a download link to your problematic design and the step export. Someone have a possiblity to try them. Now you get guesses and workarounds. \$\endgroup\$
    – user136077
    Aug 30, 2017 at 3:42
We do such imports (Altium -> STEP -> SWX) all the time and never ever did we get such error message (some boards have ~2k parts). Try changing the 3D Model for the connector to .. say .. an extruded Box in your library, then try to export it again. I have a feeling that the model might be faulty.
Also, make 100% sure that you're not using a variant in Altium and double check that your OutputJob settings for the 3D STEP export are set to "No Variants" so it exports all parts. At least for this try.
  • \$\begingroup\$ Yes, Altium does not export .sldprt into step by itself. that was it. \$\endgroup\$
    – PyThagoras
    Aug 31, 2017 at 16:35
Thank you your replies, but it was not exactly what solved my problem. I'll share my findings:
1- If it happens to someone, look first of all if all your models on altium are already in STEP, because they HAVE to be. The models that disapeared for me were SLDPRT (solidwork parts). I changed them to STEP and everything worked, but one of the pieces was still missing.
2- sometimes, solidworks decides that an assembly is too complex and supresses some parts. To forbid solidworks from doing that you need to go to the template file of the part/assembly file located in: ProgramData/SolidWorks/Templates. Open thoses files and go in the properties tab on the left. In advanced options, uncheck to "Supress new component" box. Save it all and start loading your file again.
Those two steps solved it for me. Thank you!
