33
A question so simple I've never thought about it before. Usually I get my PCBs made in standard green, but have been offered a blue for my next revision of an existing (green) board at no extra cost.
What colors are available as standard, and why should you choose one over another. Is there a "best" color?
Would any of this affect color blind tech people who work on the board?
  • 32
    \$\begingroup\$ I like my soldermask in camouflage. It adds a bit cost but makes it harder for the bad guys to find my stuff. \$\endgroup\$
    – PlasmaHH
    Aug 30, 2017 at 9:21
  • 16
    \$\begingroup\$ I normally use green, but reserve red for prototype boards so they can be put through the factory without anyone mistaking them for production boards. \$\endgroup\$
    – Steve G
    Aug 30, 2017 at 10:35
  • 47
    \$\begingroup\$ If you're selling to audiophools, then each color has a different sound. \$\endgroup\$ Aug 30, 2017 at 11:10
  • 4
    \$\begingroup\$ Don't trust black from any old supplier for critical stuff, though - dying plastics of any kind black can involve ever so slightly conductive carbon pigments, which could increase leakage currents or lower dielectric strength. \$\endgroup\$ Aug 30, 2017 at 12:16
    \$\begingroup\$ Beware some colors make more difficult to inspect the boards (like black). Also, if you do low volume or only prototyping and use an IR reflow oven (not convection) for soldering red and black PCBs you will need to adjust the thermal profile (the first time I tried red PCBs, I burned the first batch). I guess the opposite applies for white PCBs (I have not tried those). I've heard that some colors make the flux residues stand out more than others (in case you don't clean it because you use no-clean flux) but I haven't had that problem. \$\endgroup\$
    – MV.
    Aug 30, 2017 at 22:25
10 Answers 10
8
As said by others, the color is the result of the solder mask used.
However, it's definitely not true that color is the only difference. For example, Paul Stoffregen of Teensy fame found that a black solder mask had reduced resolution than a green solder mask, and this directly led to lower reliability of black boards.
  • \$\begingroup\$ This is likely PCB manufacturer dependent. I have seen tons of high-density black boards which didn't have more issues compared to e.g. green ones. \$\endgroup\$ Aug 31, 2017 at 8:49
  • \$\begingroup\$ Depends on the material and equipment used. I mentioned in my answer not-green may have worse specifications. The PCB fab will usually tell you about it if it's an issue. If they have black as stock, it's unlikely to be a problem or at least they have clearances you need to use. \$\endgroup\$
    – Barleyman
    Aug 31, 2017 at 9:55
  • \$\begingroup\$ Aren't most Apple PCBs black nowadays? Also lots of flagship phones... I think it's just if some shitty board shop decides to use some budget black soldermask (colored with carbon black) that you'd have problems. \$\endgroup\$
    – Nick T
    Aug 31, 2017 at 18:59
    \$\begingroup\$ In 2008, our Contract Manufacturer advised us that if there were narrow "webs" of solder mask thinner than .003", then the slivers of green solder mask would sometimes disconnect and you would have no solder mask between pads. This minimum width went up to .004" if using blue solder mask. Apparently due to the pigment used. This appears to have been based on their experience with their manufacturer and may be anecdotal. It is possible newer formulations of non-green solder mask resolve this issue. \$\endgroup\$
    – 1N4007
    Sep 1, 2017 at 15:51
30
The color comes from the soldermask, so what you're really asking is what colors of soldermask are available. The answer is that you can get just about any color soldermask, but the less common ones may cost more depending on your manufacturer. Different manufacturers offer different standards. One manufacturer may only offer green as standard and you'll need to pay a premium for blue, red, etc.
To answer your main question about what is commonly available, I have seen green, blue, purple, red, black, and white. Those seem to be the most popular. At work we use green boards to indicate leaded assemblies (because in the past, prior to RoHS restrictions, all of our boards were done in green), blue to indicate RoHS-compliance, and red for prototypes. There is no "best color", it is completely up to you. Personally I don't care for black soldermask or white soldermask because it is difficult to see the traces which could be useful for troubleshooting.
  • 9
    \$\begingroup\$ There are some slight differences between the different solder masks for speciality situations (very-high-impedance circuits where nA leakage is significant, characteristic impedances, etc.) However, when you are dealing with those kinds of situations you often omit the solder mask entirely. (or at least in that location) \$\endgroup\$
    – Joren Vaes
    Aug 30, 2017 at 13:00
  • \$\begingroup\$ Is no-color (I mean, transparent) available? \$\endgroup\$ Aug 30, 2017 at 16:14
  • \$\begingroup\$ I believe so, though I have never seen it in person. I imagine it is a high-price item though. \$\endgroup\$
    – DerStrom8
    Aug 30, 2017 at 16:40
    \$\begingroup\$ @DoktorJ I had them in mind when I wrote this but purple soldermask is usually considered non-standard for most manufacturers. I often wonder why OSHPark chose that for a color. Probably to make their boards stand out ;) \$\endgroup\$
    – DerStrom8
    Aug 30, 2017 at 21:38
    \$\begingroup\$ FWIW, I chose Yellow when ordering from PCBWay and it was a pretty nasty gold sort of colour. Wish I'd just gone green :) \$\endgroup\$
    – Matt Lacey
    Sep 1, 2017 at 5:27
7
It's just paint so various colours are available. Okay, it's a special kind of paint so you may get worse specs on not green colour as that's by far most common one. Specs meaning the smallest bridge and clearances.
I've made black and white boards, LED backlights are white for obvious reasons. If you just take regular white colour solder resist, you're liable to end up with pink as the copper will show through. Red is also seen from time to time.
Black PCB with gold (ENIG) treating looks cool but it's harder to see the traces than on green PCB.
Usually I spec on my PCBs "Black if no extra cost"
  • 8
    \$\begingroup\$ No, it's not just paint. The main color of a PC board comes from the solder mask. The "just paint" layer is the silkscreen, which is usually white. \$\endgroup\$ Aug 30, 2017 at 11:12
    \$\begingroup\$ @OlinLathrop Oh come on. Silkscreen has nothing to do with PCB colour. Wrt solder resist, I have worked with PCB fab that will actually mix you colour you want if you pay extra. Obviously you don't want that as it costs extra and black resist materials are widely available if not everywhere. \$\endgroup\$
    – Barleyman
    Aug 30, 2017 at 12:23
  • 12
    \$\begingroup\$ @Barleyman I think OIins point is that solder resist has a very specific function, which is to repel molten solder so that solder retreats to the soldered pads/pins, greatly reducing the chance of solder bridges. Its color is merely a side effect to that main functionality. In that sense, I agree solder resist is not "just paint" :) \$\endgroup\$
    – marcelm
    Aug 30, 2017 at 13:21
  • \$\begingroup\$ Solder resist is what gives normal PCB base material its CTI rating and should not be overlooked. \$\endgroup\$
    – winny
    Aug 31, 2017 at 21:05
    \$\begingroup\$ @Barleyman For consumer devices, sure. For industrial, it becomes important for compliance and lifetime. \$\endgroup\$
    – winny
    Sep 1, 2017 at 10:55
An additional "why" ... when possible, I also like to use soldermask colors to denote prototype/test PCBs vs. production. I may have a red or purple (OSHPark) prototype board to test functionality and then move to green for production. I find it helpful when showing photos of a test setup in a work instruction or test report as someone can tell at a glance why flavor of hardware I was using.
I've also used soldermask colors to denote board revisions in a similar manner so that quality inspection or manufacturing doesn't get confused, especially contract manufacturers who may have multiple revisions in the warehouse. Somewhat of a last line of defense just in case.
The colour of commercial PCBs comes from the soldermask. Typically the soldermask "ink" is laid down onto the board using a screen-printer, then the ink is cured and finally a photoimaging process is used to make the gaps.
The soldermask "ink" comes in a variety of colours and custom colours can be mixed. The trouble is to change colour requires cleaning the screen printing equipment which wastes a bunch of time and ink. So muost vendors will have a limited list of standard colours which they produce in enough volume to make it worthwhile keeping a screen printer set up for them.
Note that some colours are more transparent than others. White and black soldermasks in particular tend to make it much harder to see the tracks under the soldermask. Depending on your goals you may see that as an advantage or a disadvantage.
Each manufacturer will have standard colors- sometimes you can even specify matte finish for some colors. Eg. matte black or green. Most common colors are green, red, blue, yellow, black and white. White is useful for LED boards because it reflects more light, some folks think black with gold is attractive. Yellow tends to be more transparent than the other colors.
You can even ask for a specific color to be produced in some cases - of course there will usually be significant extra costs and/or significant minimum quantities associated with matching a custom color.
There's not a great advantage of one over another in most situations. I have used black for PCBs used in a vacuum to increase emissivity.
  • \$\begingroup\$ You need special white coating for LED bars, LEM3 et al. As I said, regular solder resist mixed white can turn out pink.. \$\endgroup\$
    – Barleyman
    Aug 30, 2017 at 12:27
  • \$\begingroup\$ @Barleyman Normally pink costs extra. \$\endgroup\$ Aug 30, 2017 at 13:53
  • \$\begingroup\$ You get pink for free if your white resist is not opaque enough.. And it's much lighter shade of pink than that. \$\endgroup\$
    – Barleyman
    Aug 30, 2017 at 14:38
  • \$\begingroup\$ The "pink" in Sphero's picture looks like a nominally red soldermask on a board with lots of outer-layer copper. \$\endgroup\$ Aug 31, 2017 at 16:38
  • \$\begingroup\$ @PeterGreen It's listed as pink color in the manufacturer's web page. Probably red mixed with a bit of white. \$\endgroup\$ Aug 31, 2017 at 17:13
I just want to add that most manufacturers will indeed charge you money for any other solder mask color than green. The reason for that is that the set-up for different solder mask color is much more difficult and will stop the production line just for your PCBs. But what you can do is to arange the manufecturer to paint your pcb with a legend ink, since usually they have different colors and it's very easy to change the ink tubes.
Of course, if you paint your PCB with the legend ink, you can't print any other ink legend anymore. At least not till the first ink layer is wet. If you are doing high-density PCBs this shoudn't be a problem, because there won't be place for legend anyway. The other option you have is to use solder mask to write the legend in gold or silver, depending on the finish you are using. The manufacturer should be smart enough not to cover anything free from solder mask with legend ink, but you can define it by yourself in the e-data you are sending them.
I'm doing that for one of my PCBs and it's working pretty good so far.
    \$\begingroup\$ A different solder mask color is not much more difficult, but changing the color using the same machine needs work, causes delays and and produces more waste. If the manufacturer has different machines for different solder mask color, there is no delay, but the additional machines cost money. \$\endgroup\$
    – Uwe
    Aug 30, 2017 at 14:30
  • \$\begingroup\$ Maybe, but I haven't seen in my life a manufacturer that hasn't utilize it's machines and it's keeping one machine for a special solder mask color. Fact is that I don't know a single manufacturer that won't charge you for different solder mask than green. If you know such, please tell me. \$\endgroup\$
    – judoka_acl
    Aug 31, 2017 at 10:58
I don't recommend using black for a 1st revision because it's hard to see if a part blew out, but I guess that could be a design benefit on a deliverable...
Green is obviously the standard, if you take a sample of 1000 different PCB's from different manufacturers, green is clearly the winner. So if you want a standardized board color, you'd better order green.
If your a rebel and like to go against per-defined standards, then go for purple or orange, or if you really need attention, "hot pink". If you just want something different blue will suffice
Yes, you need to implement a system like RHOS to control how much color is on the boards and a require that all products have the correct color of board so that no more color blind people need to suffer.
Colors like green, blue and red are used commonly, as said by others, for lead containing pcb (e.g. solder), RoHs compliant one, and prototype. It's a good choice to distinguish things.
We use black for power dissipation, when we pack a lot of Amps: painting something in black makes a difference. I never noticed effects of lack of insulation, although I confess that I never made an accurate measurement and that the circuits where black soldermask was used are all low voltage (up to 100 V).
