Can anyone help identify connector type for A & C below or suggest site/keywords I could use to narrow search? I have sent inquiry to several sites selling automotive connectors and Googled extensively but no success :-(
Update for anyone else interested: Contacted Metra directly and they have no solutions. Poured through Mouser and no plugs which match socket.
    \$\begingroup\$ tends to be proprietary , plug to board-conn with two blade sizes, x pins, y spacing, keyed, interlocked, shrouded. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 30 '17 at 17:29
This is the closest I could find. https://www.amazon.ca/s/?ie=UTF8&keywords=metra+harness&tag=googcana-20&index=aps&hvadid=208327070378&hvpos=1t1&hvnetw=g&hvrand=10278463606330088444&hvpone=&hvptwo=&hvqmt=b&hvdev=t&hvdvcmdl=&hvlocint=&hvlocphy=9000793&hvtargid=kwd-296824187433&ref=pd_sl_6g6ti6sqkh_b
I leave the rest up to you.
Or call them direct http://metraonline.com
  • \$\begingroup\$ Thanks. I did look at wiring harnesses for Hyundai 1st but unfortunately the system in Genesis model is produced by Lexicon and doesn't follow standard Hyundai configuration. I was hoping to go different direction by figuring out manufacturer (assuming they are using mass-produced connector and not a custom variant). \$\endgroup\$ – Brian Miller Aug 30 '17 at 17:53
  • \$\begingroup\$ probably 500 pc minimum order. How many k do you need? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 30 '17 at 17:54
  • \$\begingroup\$ Ouch, only need male/female for A & C. \$\endgroup\$ – Brian Miller Aug 30 '17 at 17:59
  • \$\begingroup\$ go to audio jobber and beg for scraps \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Aug 30 '17 at 18:04
  • \$\begingroup\$ Did you mean auto jobber? If not I'm not finding anything for "Audio Jobber"? \$\endgroup\$ – Brian Miller Aug 30 '17 at 18:50
