I have some problem with a P-channel mosfet used as high-side load switch. Everything works fine beneath the power up moment.
You can find the schematic in the picture below.
During Powering the circuit with 28V the following happens (blue channel: Gate; green channel: Drain):
I suppose that this flicker occurs because of the Gate Capacitance of the MOSFET, but I am not sure. Does somebody of you have an idea on how to solve this problem? During this period the output signal should stay at GND level.
Furthermore, I want to tell that on the input there will be a 5 kHz PWM coming from a Microcontroller. As I said before, after the power-up, there are no problems. Edit: The PWM is started after some ms.
Regards Armin
  • \$\begingroup\$ Those R values seem rather high for gate control... especially if you plan on using it for PWM. \$\endgroup\$
    – Trevor_G
    Aug 31, 2017 at 14:27
  • \$\begingroup\$ You also seem to be driving that gate to significantly lower than the 10V VGS the part requires. \$\endgroup\$
    – Trevor_G
    Aug 31, 2017 at 14:41
  • \$\begingroup\$ Do you think that the gate current is too low with these resistors? I am driving it down to 8V which should be ok. I read +/- 20V Vgs in the datasheet. \$\endgroup\$
    – Armin
    Aug 31, 2017 at 17:09
  • \$\begingroup\$ -20V is the absolute max though... that leaves you no room for variation in the 28V and any other noise spikes. If you look at the other figures it's really defined at -10V, which makes that the manufacturers "normal" operating point. \$\endgroup\$
    – Trevor_G
    Aug 31, 2017 at 17:14
    \$\begingroup\$ And yes I'd drop those resistor values by at least a factor of 10. R1 is also unnecessary. \$\endgroup\$
    – Trevor_G
    Aug 31, 2017 at 17:16
Those R values seem rather high for gate control... especially if you plan on using it for PWM. I'd drop those resistor values by at least a factor of 10. Lower resistances will also mean the MOSFET will switch faster and run cooler when you PWM.
Incidentally, R1 is also unnecessary.
You also seem to be driving that gate to significantly lower than the -10V VGS the part is specified to. You are driving it down to 8V, which is -20V VGS.
From the spec sheet, -20V is the absolute max value... that leaves you no room for variation in the 28V, part tolerances, and any other noise spikes. If you look at the other figures it's really defined at -10V, which makes that the manufacturers "normal" operating point.
