I'm trying to make a CNC machine out of 2 dvd drive stepper motors. One of my stepper motors is completely normal and as seen in every video I've seen on the topic. The other looks like this (see pictures). The laser diode assembly moves on some gears connected to a motor which is connected to a board. the board has 4 contacts but according to my multimeter, only one pair is connected. Is this a stepper motor? Also, how do I get this to work with my build?
1 Answer
The pictured motor is a DC motor, quite common in DVD drives. Components on PCB, located under the white (not-tooth wheel) are for measuring speed/spin direction for feedback control.
To make it work you have to see how to control a DC motor. Driving DC motor is quite easy. Try not to break the feedback control, you may find it helpful later.
