I have a code where I have 2 functions:
1 - read_loadcell - which reads 5 HX711 (5 load cells)
2 - rpm_read - which is supposed to read rpm's using an inductive sensor. Basically I have a metallic wheel which has 4 symmetric holes in it. Each time when a whole is under the sensor I get pin in high state.
Now my issue:
  1. If I run in loop() only "read_loadcell" is working fine.
  2. If I run in loop() only "rpm_read" also working fine.
  3. The issue is that if i run both of them, the rpm don t work anymore
So the question is how can i have them both working?
#include "HX711.h"
HX711 scale_GS1(A1, A0);
HX711 scale_GS2(A3, A2);
HX711 scale_GS3(13, 12);
HX711 scale_GS4(11, 10);
HX711 scale_FS(9, 8);
float gs1 = 0, gs2 = 0, gs3 = 0,gs4 = 0, fs = 0;
// read RPM
volatile int rpmcount = 0;
int rpm = 0;
unsigned long lastmillis = 0;
void setup() {
  attachInterrupt(0, rpm_fan, RISING);//interrupt cero (0) is on pin two(2).
  Serial.begin(9600);   //start serial communication
  Serial.println();  Serial.println();  Serial.println();
  Serial.println("/////     WELCOME     ///////");
  Serial.println();
  //set scales
  scale_GS1.set_scale(1324);
  scale_GS1.tare();
  scale_GS2.set_scale(1324);
  scale_GS2.tare();
  scale_GS3.set_scale(1324);
  scale_GS3.tare();
  scale_GS4.set_scale(1324);
  scale_GS4.tare();
  scale_FS.set_scale(1324);
  scale_FS.tare();
  Serial.println("Readings:");
void loop() {
rpm_read();
read_loadcell();
void rpm_fan(){ /* this code will be executed every time the interrupt 0 (pin2) gets high.*/
  rpmcount++;
void rpm_read(){
  if (millis() - lastmillis == 1000){  /*Uptade every one second, this will be equal to reading frecuency (Hz).*/
 detachInterrupt(0);    //Disable interrupt when calculating
 rpm = rpmcount * 15;  /* Convert frecuency to RPM, note: this works for one interruption per full rotation. For two interrups per full rotation use rpmcount * 30.*/
 Serial.print("RPM =\t"); //print the word "RPM" and tab.
 Serial.println(rpm); // print the rpm value.
 rpmcount = 0; // Restart the RPM counter
 lastmillis = millis(); // Uptade lasmillis
 attachInterrupt(0, rpm_fan, RISING); //enable interrupt
void read_loadcell(){
  scale_GS1.power_up();
  gs1 = scale_GS1.get_units();
  scale_GS1.power_down();
  scale_GS2.power_up();
  gs2 = scale_GS2.get_units();
  scale_GS2.power_down();
  scale_GS3.power_up();
  gs3 = scale_GS3.get_units();
  scale_GS3.power_down();
  scale_GS4.power_up();
  gs4 = scale_GS4.get_units();
  scale_GS4.power_down();
  scale_FS.power_up();
  fs = scale_FS.get_units();
  scale_FS.power_down();
  Serial.print("GS1 :\t");
  Serial.print(gs1);
  Serial.print("\t GS2 :\t");
  Serial.print(gs2);
  Serial.print("\t GS3 :\t");
  Serial.print(gs3);
  Serial.print("\t GS4 :\t");
  Serial.print(gs4);
  Serial.print("\t FS :\t");
  Serial.println(fs);
| improve this question | | | | |
#include "HX711.h"
// read RPM
int rpm = 0;
void setup() {
  Serial.println();
  //set scales
  scale_GS1.tare();
  scale_GS2.tare();
  scale_GS3.tare();
  scale_GS4.tare();
  scale_FS.tare();
void loop() {
rpm_read();
read_loadcell();
  rpmcount++;
void rpm_read(){
  unsigned long elapsedTime, localRpm, interruptCount;
  elapsedTime = millis() - lastmillis;
  if (elapsedTime >= 1000) {
    noInterrupts();
    interruptCount = rpmcount;
    rpmcount = 0;
    interrupts();
    localRpm = 15 * 1000 * interruptCount / elapsedTime ;
    Serial.println(localRpm); // print the rpm value.
  Serial.print(gs1);
  Serial.print(gs2);
  Serial.print(gs3);
  Serial.print(gs4);
  Serial.println(fs);
| improve this answer | | | | |
