I am trying to use ADS to create the scheme of an amplifier which includes the following elements
B1:
Description = 100 MHz Short Ferrite Bead, Surface Mount
Part Number = 2743019447
Manufacturer = Fair--Rite
C1:
Description = 5.6 pF Chip Capacitors
Part Number = ATC600B5R6BT500XT
Manufacturer = ATC
However, I am unable to find ferrite beads in the components library (should I use simple inductors instead?). Also, what is the importance/relevance of the part number and manufacturer? How should this information affect the components I select from the components library? I'd appreciate some insight on this, please.
