I'm trying to find solutions for the security of an outdoor area (2km long and 1km wide). We want to detect any breach through the borders of the area, if someone sneaks in and/or someone goes out.
What I'm trying to achieve is to have the least detection nodes possible on the borders that use solar power packs to take their juice from. Let's assume that we can have 5-10 nodes in 2km length (max of 1 node each 200m) and 5 nodes in 1km width of the area. We'll have a gateway that receives the data from these end devices once motion is detected through RF (and that's not a problem). These motion sensors should be able to detect movement up to 200m away (until the next node), only detect human movements (not pets, cars, etc.), work with arduino or RPi and don't be in need of too much power.
I've done some research already, but I thought maybe someone could introduce me to an specific sensor or solution.
  • \$\begingroup\$ Is a thermal camera in budget? \$\endgroup\$ – Jeroen3 Sep 1 '17 at 7:30
  • 4
    \$\begingroup\$ sure, arduino can do everything. You are talking about the system complexity that even border patrol doesn't have it and you wish to solve with an arduino and 10 bucks. \$\endgroup\$ – Marko Buršič Sep 1 '17 at 7:43
  • \$\begingroup\$ There are many ways to detect such things. All have their own strengths and weaknesses. There is no perfect system - and certainly no "cheap, low power, only detect people" system. You will always have to deal with false positives (small animal triggers your alarm instead of a person) and false negatives (person sneaks through without being detected.) The more you can put up in the way of detectors (of different types) and processing (to combine the sensor readings to filter out the bad results) the better it will be. \$\endgroup\$ – JRE Sep 1 '17 at 7:58
  • \$\begingroup\$ motion is detected through RF (and that's not a problem). I Agree These motion sensors should be able to detect movement up to 200m away That's not going to happen with cheap RF sensors only detect human movements (not pets, cars, etc.) That's only possible in SciFi movies ! \$\endgroup\$ – Bimpelrekkie Sep 1 '17 at 8:26
    \$\begingroup\$ Have you considered landmines? \$\endgroup\$ – Gregory Kornblum Sep 1 '17 at 8:37
