For my project, I need to design a simple EEG circuit. As known, input signals are in micro volts.
After some research I understand that I should use an inst. Amp. to process the signal. Voltage gain should be 100.
The question is how I can choose the appropriate ins. amp ? Any help or guide will be appreciated.
Sincerely.
  • \$\begingroup\$ Usual voltage gain is more like 1:100,000 - if you can block the DC offset somehow. \$\endgroup\$ – Turbo J Sep 1 '17 at 22:42
  • \$\begingroup\$ Is there any source that we can see what component are okay for our specific purposes ? \$\endgroup\$ – PIC16F84A Sep 2 '17 at 13:25
I would redirect you to consider the ADS1298 which has the Right leg drive (RLD)and everything else you need for ADC.
http://www.ti.com/lit/sg/slyt416/slyt416.pdf
The ADS1294/6/8 are a family of multichannel, simultaneous sampling, 24-bit, delta-sigma (ΔΣ) analog-to-digital converters (ADCs) with a built-in programmable gain amplifier (PGA), internal reference and onboard oscillator. The ADS1294/6/8 incorporate all of the features that are commonly required in medical electrocardiogram (ECG) and electroencephalogram (EEG) applications
    \$\begingroup\$ TI has the ADS1299 specific for EEG applications. ADS1298 has noise in one of the EEG bands - at least on our test bed. \$\endgroup\$ – Turbo J Sep 1 '17 at 22:40
    \$\begingroup\$ oh? which band? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Sep 1 '17 at 22:55
