There is an analog input voltage pin of a microcontroller whose threshold voltage is set 0.2V. If the input voltage at the pin is below 0.2V, then it is recognised as the short circuit to ground(SCG). A value for the debounced time should be chosen in ms. When the input voltage is below 0.2V for a time as long as the debounced time, then the error bit SCG is set. Do you have an idea how i can calculate the optimum debounced time?
    \$\begingroup\$ I have trouble understanding the problem. Most likely you know all about the system you are designing, but I don't. Please provide all the information you can, too much information will not hurt, but too little means noone can answer. \$\endgroup\$ – peufeu Sep 1 '17 at 21:24
  • \$\begingroup\$ most microbutton switches 5ms \$\endgroup\$ – Sunnyskyguy EE75 Sep 1 '17 at 21:29
  • \$\begingroup\$ @ peufeu Thanks for the comment. - The problem is I do not know how to calculate the debounce time for debouncing a 'high' - the high comes when there is a short circuit to ground. A short circuit to ground(SCG) may come just for a few microseconds at the analog input pin and then vanish. An SCG for a few microseconds may not be enough to set the error bit SCG. So, how many seconds are enough to call it an SCG? \$\endgroup\$ – slM201z Sep 1 '17 at 21:32
  • \$\begingroup\$ @TonyStewart.EEsince'75 thanks. This debounce seems less relevant to switch debounce, so i haven't found any material on the net. \$\endgroup\$ – slM201z Sep 1 '17 at 21:35
    \$\begingroup\$ it depends what you are connected to \$\endgroup\$ – Sunnyskyguy EE75 Sep 1 '17 at 21:39
SCG is a common automotive ECU fault diagnostic function such as the O2 sensor which is a field replaceable part.
It may be a long time in ms e.g. 500ms but not too long to stall the engine.
this spreadsheet shows some ECU fault detection parameters that may be useful.
http://dulevo.com/documenti/codici-guasto-5020e6.xls
  • \$\begingroup\$ Tony, thanks for your answer and the document. :-) \$\endgroup\$ – slM201z Sep 1 '17 at 22:50
  • \$\begingroup\$ Hello Tony, are there other parameters which help to calculate the exact value of the debounce time? For example, the open pin voltage of the pin - that the debounce time for SCG should be kept shorter if the voltage gets larger. \$\endgroup\$ – slM201z Sep 2 '17 at 8:50
