I just made a fresh install of iCEcube2, first time i'm using it, and whatever design files I use I've got this error when I try to synthetize :
/opt/iCEcube2.2017.01/synpbase/bin/synplify_pro: 321:
/opt/iCEcube2.2017.01/synpbase/bin/config/execute: Syntax error: "(" unexpected (expecting ";;")
I'm using ubuntu 16. No idea what happens, and I don't know what I could do knowing that it's a fresh install. I tried to launch the software in sudo with same result.
Thanks
the issue here is that the "execute" script that iceCube2 is trying to run, is using as "shell" /bin/sh linked to /bin/dash, in Ubuntu, instead of /bin/bash.
the best workaround i found, is to change the shell from /bin/sh to /bin/bash in the first line of all the shell script in these directories..
/opt/iCEcube2.2017.01/synpbase/bin/ /opt/iCEcube2.2017.01/synpbase/bin/config/
  • \$\begingroup\$ Answering poorly received questions is kind of discouraged. You should also take your time to capitalize properly. \$\endgroup\$ – Oskar Skog Sep 29 '17 at 12:59
  • \$\begingroup\$ Ty for your answer :) \$\endgroup\$ – Cart3sianBear Oct 16 '17 at 16:23
Thanks to Andrea Venturi for tip on the root cause. Indeed /bin/sh has very special meaming in Unix. For regular scripting /bin/bash should be used. Here how to fix all iCEcube2 scripts:
$ cd <iCEcube2.2017.01>/synpbase/bin
$ find . -type f -exec sed -i 's/\/sh/\/bash/g' {} \;
